1 - 20 of 23 Posts
Hi Guy's. I was wondering what would be the best size sealed enclosure for the svc TC-2000 powered by the ep2500?
You would think I have been here long enough to know what info you would need.:duh: I will have to hunt the parameters. It is a 15''
Here the specs Mike.
15" TC-2000 SVC
Qts 0.321
Qes 0.347
Qms 4.264
Fs 18hz
Res 3.19Ω
Ls 2.45mH
Lp 5.87mH
Rp 4.30Ω
Dia 330mm
Vas 267l
mms 296g
cms 260um/N
bl 17.2T*m
Spl 88.5dB
Doesn't look good for HT does it........:no:
Discussion Starter · #10 · (Edited)
It is 260 liters or 9.182cf. Got any ideas or could I just cut it down to resize it?
So cutting the tube down to 6cf isn't a good idea? Or is it because I couldn't put a long enough port in it after cutting it. I am just trying to think of all my options.
Discussion Starter · #14 ·
It is 25'' wide.
Unfortunatly I can't make it smaller.......:no:
Discussion Starter · #18 ·
I would probably go for the 6cf you plotted. I appreciate all your help Mike...:T
Discussion Starter · #19 ·
Well I took the Shiva out of the 4cf box, made the hole bigger and put the TC2000 in. I put the Shiva in a smaller box I built and now they both are playing nice together. Here is a graph and some pic's.:yay2:
I can't get rid of that bumb at about 70hz. Any change I make just makes something else worse so for now it is what it is. I put up some more acoustic panels I built also, 4 on the cieling and some on the front wall. I can get back to watching and listening again until.....:heehee:
1 - 20 of 23 Posts
