361 - 380 of 404 Posts
Yes, the system has evolved over time to where it is now. The front ends are a SOTA Cosmos turntable with Eminent Tech ET2 air bearing arm and Garrott custom cartridge, feeding a VTL TP6.5 phono preamp, VTL TL 7.5 pre. A Wadia 4 box 9 series player handles CD playback and a German T+A MP3000HV handles internet radio, FM and network streaming duty. All cables are Transparent XL. The room is built from straw bales plastered with lime plaster. Thee are over 6 tonnes of plaster in this one room alone ! The room has turned out really nice acoustically, having near perfect RT60 and very flat response. I have some bass traps in the corners to tame a few bass lumps, but otherwise minimal treatments. My idea was to keep damping to a minimum by balancing hard & soft materials at the construction stage. If anybody is interested in more detail on the room side of things I can post an article in the appropriate thread.
Fixed the photo link in post 361. Very nice.
...The room is built from straw bales plastered with lime plaster. Thee are over 6 tonnes of plaster in this one room alone ! The room has turned out really nice acoustically, having near perfect RT60 and very flat response. I have some bass traps in the corners to tame a few bass lumps, but otherwise minimal treatments. My idea was to keep damping to a minimum by balancing hard & soft materials at the construction stage. If anybody is interested in more detail on the room side of things I can post an article in the appropriate thread.
Straw bales! Six tons of plaster! OK, I for one am extremely interested! How about a thread over in the Home Theater Design and Construction forum? All the detail you can muster. We are all ears!
Yes, indeed - that is one fine system in one fine environment. Such a wall is a superb sound insulator and behaves somewhat like an omnipresent bass trap. Certainly, no room can be perfect, but I imagine it has a very natural sounding response. I assume it's also built with calculated dimensions (a well distributed cuboid is an excellent shape, acoustically speaking). I don't know where to start with the system, but I love the fact that such systems are out there - simply superb system.
Thanks for sharing, and do share more details of the construction in the aforementioned thread.
Have posted a picture - apologies for the poor quality, had to take it with my iPad as daughter has my "real" camera !
NICE!!! color me envious
I have a good friend with a pair of Beta's he bought used from Woodbridge Audio in NJ and then sold me his RS IIa's. Trying to lever the Betas from him but he won't budge. ;). In the meantime, they sit idol in crates as he is building his biz overseas. Such a waste.
I love my Betas, just thinking about upgrading the old caps in the crossovers.
Only way I would part with them is if I came across a mint set of IRS V's... those are what I have always wanted.
I love my Betas, just thinking about upgrading the old caps in the crossovers. Only way I would part with them is if I came across a mint set of IRS V's... those are what I have always wanted.
You have the room for the big boys! Try this guy...http://www.ebay.com/itm/Original-INFINITY-RS-1b-NO-MODIFICATIONS-STOCK/281206372240?rt=nc&_trksid=p2047675.m1851&_trkparms=aid=222002&algo=SIC.FIT&ao=1&asc=163&meid=3008331674283790363&pid=100005&prg=1088&rk=2&rkt=3&sd=281159948900&.
Not the V's but closer!
I also need to upgrade / refresh the electronics on my. RS IIa's. Lots of help on the 'gon for that but haven't got my head into it yet as I simply don't understand it. For me, it would be replace one part at a time with a new one of exactly the same spec. I could not get creative as I have no idea what any of the parts do. I think this is needed since they are all original and the adjustments on the back of the speakers have NO EFFECT and one is brighter than the other - ever so slightly. (Could also be I am less sensitive in y right ear...) what a hobby
You will probably find that the potentiometers in the RS's have become clogged up with gunk & just need a clean. I use Caig Labs DeoxIt D5s which you just spray into the small holes in the side of the pot and then rotate the knob back & forth a few dozen times to distribute the fluid. This will fix all but totally stuffed pots !
I have done this for the connections and the knobs on the EQ but have not sprayed it into the pots in the speakers. Guess I will try.
Revel Salon2 is the best speakers that I have heard but it also has
a nice format.
It is narrow, which makes it fit into rooms that are not so great.
I really enjoy reading these post. I live in Kentucky and it is hard to listen to really good stuff anymore. We used to have a high end shop and I remember listening to some big Martin Logans and was blown away. I have a friend that has some 70's model Snells that sound so good to me.
I had 2-3 sets of Polks and someone loaned me some Rogers and I knew I had to have something different. I found ACI on the net and purchased the Sapphire lll LE's from Mike. I still listen to them daily. I would love to hear some Salk's or Vapor's now. I never liked really bright speakers that I have heard. I am in my mid 50's now and would like to upgrade, just don't know what to look at or where. Guess I need to plan a road trip.
One of the best speakers that I own are the Boston E60 speakers, they
throw a big soundstage, with real good detail, definition and depth.
And they are smooth - HT Labs measurements >>
The E60's listening-window response measures +1.25/–0.97 dB from 200 Hz
to 10 kHz. The –3 dB point is at 65 Hz, and the –6 dB point is at 53 Hz.
Impedance reaches a minimum of 4.36 ohms at 203 Hz and a phase angle of
–58.73 degrees at 111 Hz.
There are still some at Amazon
http://www.amazon.com/Boston-Acoustics-E60-Performance-Bookshelf/dp/B001H9O1CQ/ref=sr_1_1?ie=UTF8&qid=1387389025&sr=8-1&keywords=BOSTON+E60
A closer image
http://i.seimg.net/images/309923/big/combo-pair-e60-black_efl.jpg
a nice format.
Revel Salon is a great speaker, these belong to my friend Gerard and they are fed by Classé mono blocks.
Living in Hawaii does not give us much options on what speakers can be auditioned. There is really only one real hifi store and it's a small shop. They carry JBL's top line speakers (they even have an old Paragon on display) that sells for $10,000+.
They also carry Magneplanars and I have to admit that I have not heard anything better that their 20.7s. If I had the money and the room for it, I would buy it in a heartbeat...
And you Jon would be doing a very good thing.
I have to say that for movie use the best speakers that I've heard so far are the ones I currently own, JTR 228HT's. I still haven't heard anything that can play as loud as they can while still remaining crystal clear without a hint of distortion.
With ear plugs in I've had my system turned up to about +5 over reference and with my SPL meter in hand from my LP I was hitting peaks of 118dB while watching a few scenes from Pacific Rim.
