1 - 9 of 9 Posts
I am trying to determine the best home theater speaker arrangement for my room. The challege is the room is open on one end - meaning one of the side walls is actually much further away (i.e. leading to the stairs and hallway) thus I really can only easily get speakers on 3 walls (Front, Rear and Right side), thus I am considering ceiling speakers for my rear surrounds. In addition, the room depth is only about 14 feet, thus my couch backs-up almost to the back wall.
I am open to any ideas on what type and how best to mount the surround speakers. I recently read keelay's thread and that seems the most interesting so far.
http://www.hometheatershack.com/forums/diy-speakers/18046-rb-kit-ceiling-surrounds.html
Any other suggestions?
Thanks.
Have you thought about stands for the surround speakers? You could have them flank the couch, or just put the one on the open end on a stand.
I used to have Atlantic Tech 350's on stands and they looked pretty good and sounded great.
A quick picture (Google sketchup, powerpoint, hand draw and scanned) would help out quite a bit.
I've been experimenting with surround options and the one I prefer so far is described here.
http://linkwitzlab.com/surround_speaker.htm
I've got a similar layout; 15x22 room with a 5' doorway at the left (15') side. I keep the seating area a good 3' away from the back wall and so have a 10' viewing distance. The simple, single, full-range driver omni set-up in the link is beating the out of the several direct-radiating options at my disposal (not a very comprehensive choice), without any EQ. They're floor-standing, small footprint and can be painted to match the decor if desired. The challenge in your case is the absence of any wall on the open side, but I suspect the resulting sound level difference can be compensated by increase gain in that location. Sound leakage will be bad, but it's already bad I suspect.
Have fun,
Frank
I always try to talk people out of going with In Ceiling/Wall speakers as you always loose performance and quality going that route. If your not dead set against having a bookshelf speaker hanging from the ceiling that would be a far better choice.
Does anyone know of a good simple article on 5.1 speaker placement? All the pictures I see are totally different with regards to rear surrounds.
Dolby has a great setup guide located here
I have actually been thinking of 'hanging' some bookshelf-type of speakers such as was suggested, but since I have a relatively low (8 ft) ceiling, I have been thinking about recessing them somewhat like the way it was done here:
http://www.reefworkshop.com/speakers/
Has anyone else done it this way? What might be the pros/cons with this?
That is an option just make sure that the speakers are front ported not rear.
1 - 9 of 9 Posts
