1 - 4 of 4 Posts
I'm going to hang 4 on the front wall and want them to be level. Any tricks :reading:? I'm sure the wire
on each panel is not the same tightness . I would have to wrap tape around the wire of
the low hanging ones. I was thinking of using the nylon wall drillers
http://www.factsfacts.com/MyHomeRepair/images/NylonWallDrillerSpecs.gif
Also what is the recommended distance between the panels to take advantage of the side absorbtion
of the panels?
Thanks
HTS Senior Moderator
Concentrate more on where the fronts need to be. If you have 4-6" between panels, that will take advantage of the extra side absorbtion.
As for hanging, just wrap the wire around the hook another time or 2 to shorten it up if you need to.
Bryan
1 - 4 of 4 Posts
