Beta 18 won't install on Win7
1308 Views 3 Replies 3 Participants Last post by  AustinJerry
Downloaded the installation file named "47635d1395597340-v5-01-beta-downloads-asio-support-wizardinstallv5.01beta18.exe" from the downloads area, and the file will not install on either one of my Win7 systems (one 64-bit, one 32-bit).
Is the file corrupt?
1 - 4 of 4 Posts
Just downloaded the file and it installed without problems, it should be called wizardinstallv5.01beta18.exe when downloaded, size is 10,863KB. If you are using any kind of download manager I suggest disabling it.
Beta 18 downloads & installs properly for me ( on my "obsolete" XP system ) .
:sn:
When I click the download link, it shows the following file download:
Text Font Yellow Line Parallel
However, if I change the file name to "wizardinstallv5.01beta18.exe", it installs properly. Not sure how to explain this behavior, but I am now upgraded, so all is good.
1 - 4 of 4 Posts
