Status
Not open for further replies.
Manufacturer: BK Electronics
Model: Monolith-DF
Provided by: timosetae
Manufacturer link: BK Electronics
Price: 777 EUR
Manufacturer specs:
• System Type: 95 litre reflex tuned to 20Hz, cabinet manufactured from veneered 25mm MDF and critically braced
• Drive Unit: A 300mm / 12" twin magnet drive unit to increase linear excursion, a cast basket for a solid uncoloured projection of sound without ringing and vented pole piece to help reduce power compression
• Distortion: 5% 102dB @ 20Hz
• Frequency Response: 20Hz (-3 dB) / In Room 15Hz
• Amplifier Input / Output Impedance: High Level 100K - Low Level 10K - Balanced 10K
• Gain Control Range: 80dB
• Drive Unit Impedance: 4 Ohm
• Mains Input: 230V / 50Hz
• Dimensions: 420D X 604H x 540W
• Weight: 46.75kg
• Finishes: Black Ash Veneer, Light Oak Veneer and Cherry Veneer
• True 300W continuous discrete Mosfet amplifier
• 2 Years Warranty
• Truly hand built in Great Britain, when we claim hand built we mean hand built, as there are no SMD components or other automatic placement devices
• Forward Firing 300mm (12")
• Continuously variable frequency control
• Audiophile grade toroidal transformers
• Gas Tight Neutrik connection for long term consistency of sound quality
• Separate controls for high and low-level input adjustment
• Simultaneous connection of high and low level sources
• Balanced Inputs
• Thermal Protection
• Anti Thump
• ASP automatic speaker protection audibly transparent driver protection
• 4 x 16A output devices for effortless current control
• IEC Power Socket
• Doubled flared port for reduced port noise
Configuration as tested:
Phase: 0 degrees
Crossover: Bypassed
Orientation: Standard down-firing
Status
