Guys - here are some specs on the MQ-600:
•Two channels
•Individual front panel adjustable level controls
•Signal, protection, active, and clip/limiting LED indicators
•Adjustable lowpass and highpass crossovers
•Manual, auto, or triggered on/off modes
•Stereo set of heavy five-way speaker binding posts
•Stereo set of Speakon locking speaker terminals
•High current linear power supply
•High current Class AB output stage
•Heavy-duty steel chassis, rack-mountable or tabletop use
•Variable fan cooled
•Power per channel (2 channel) - Watts: 600 into 8 Ohms; 900 into 4 Ohms; 1100 into 2 Ohms
•Power, peak headroom: 3 dB (double the rated RMS)
•S/N ratio: 105 dB
•Slew rate: 80v/us
•Damping factor: 500:1
•Input impedance: 10K or 20k Ohms, balanced or unbalanced
•Power requirements: 120/230 VAC, 50/60 Hz
•Dimensions: 19" W x 3-1/2" H x 19-5/16" D
•Dimensions: 438mm W x 92mm H x 352mm D
•Weight: 50.5 lbs.
The MQ-600 is also bridgeable into mono, where it will deliver 1800 watts RMS into 8 ohms and 2200 watts RMS into 4 ohms.
This is not an inflated spec that we are used to seeing. The wattage specified is quite conservative.
And the weight at 50.5 pounds is NOT a typo. This amp is a BEAST. :boxer:
•Two channels
•S/N ratio: 105 dB
•Slew rate: 80v/us
•Weight: 50.5 lbs.
