1 - 5 of 5 Posts
Does anyone know where (or if) I could find black colored switch parts for Lutron Maestro IR switches?
I know they make them - they sell them in quite a few different colors... but I don't want to spend $120 to replace my 3 switches just to get them in black. I have been poking around online looking for just the "parts" without any success - and I emailed Lutron to see if they can sell me the parts to swap out... but I thought I would check here too.
If it comes down to having to buy all new switches I will probably just go with an Insteon setup instead...
Discussion Starter #2
...and I just got an email back from Lutron - they DO NOT sell the switch parts separately. :huh:
I guess I will first see how hard it is to take the switch apart and paint the pieces... and if that looks like a problem I will have to decide if $120 for black Lutron switches is worth it or if $250 to get started with a much more flexible, programmable, and expandable Insteon setup is a better plan.
Are you using LED lights?? If so do you get flicker, popping, or glow???
My next project in my room is lighting....if the Maestro IR switches are a problem with LED's I may be forced to use the Manual Lutron switches tested for LED lights for popping, flicker and glow.
Really would like them remote though.
Discussion Starter #4
I am not using LED lights with them.
I wish I could be of some help, but I am just using old fashioned regular bulbs ;)
Thanks for the quick reply.:dontknow:
1 - 5 of 5 Posts
