Hi folks.
I've been reading lots of advice here and I'm trying to make my own 100" Black Widow Ultra screen.
I've just finished mixing the paints and the result is... chunky! There are little chunks all through it, maybe 1-3mm in diameter. (I'd add pictures but... first post.) If I pull a chunk out and squash it, it releases a darker grey than the rest of the paint, so I'm assuming it's the aluminium not having mixed through properly? I read a warning about bubbles somewhere else, but these are definitely semi-solid chunks of pigment, not air bubbles.
Has anyone seen this before? Know the cause? Can suggest a solution? My current thinking is to go at it with a whisk for a good 10 minutes, but if I've done something majorly wrong and should just be starting again, I'd like to know now. I gave the AAA a lot of shaking before pouring it in. And because I've only used 1/4 of the bottle, now I'm also half worried that if the AAA wasn't mixed maybe my BW mix won't be the right ratio.
The base is Dulux Wash & Wear and I've got the AAA 4100 Fine.
