1 - 13 of 13 Posts
Hello,
I have a 120in Silverfire 2.5 screen I painted 7 months ago and i'm very dissatisfied with the result. One of my issues is sparkles on the screen. I'm not sure what causes this but it's real noticeable when there is a bright white image. I watch a lot of hockey and the ice looks like a twilight vampire in the sun.
Projector: Benq W1070
Throw/viewing Distance: 11'4"
The walls and ceiling are painted black with no ambient light.
I'm thinking about doing a Black Widow Ultra screen, do you think this would give me the best results? What grey tint do you recommend?
Do I need to do anything to my Sintra board or can i paint ontop of the SF?
Thanks for the help.
I live in Dallas, TX so i'm assuming I can get any paint you guys recommend. I've seen the Valspar Signature in matte finish and shermwin-williams duration matte recommened alot I can get both of those, which one is preferred?
The lamp has around 450 hours.
I've calibrated the projector with Disney WOW
Let me know if you have any other questions.
I am looking into using a piece of wilson art laminate. I think the people suggest designer white. It has some very good reviews but may be more challenging to install. There is lots to read on the subject!
I'm new to this forum and based in Dublin, Ireland so hello. I decided to go ahead over the weekend and paint a Black Widow Ultra screen directly onto a bare wall. Here's a list of the materials/process I used:
- Turned on Projector (Benq W1070 which is ceiling mounted at about 9' from wall) and selected test pattern, then I masked the edges of this with 1" masking tape which gave me abut a 140" screen
- Using wall filler and a 1" scraper I filled any pits or holes and left this to dry for one hour & using a medium sandpaper I removed any lumps and bumps
- Dulux Wall Primer (white) painted directly onto a smooth wall with a short nap roller, rolling from top to bottom, making sure I went over this again with the roller (overlapping as I went) to eliminate any streaks and left to dry for 12 hours.
- Using a digital scales I measured out 960ml of Dulux Steel Grey 2 Vinyl Matte & 240ml AAA-F paint (new batch purchased from Amazon) and mixed this with a paint paddle and an electric drill for about 5 minutes or until there was no streaks in the paint mix. I decided from reading this forum that Steel Grey 2 would be the best for my particular projector
- Using a second short nap roller I applied one coat of this Black Widow Ultra mix, again rolling from top to bottom and going back over the painted screen whilst wet, overlapping as I went to make sure there was no streaks or patches
- I left this to dry for about 5 hours as the paint would give the impression of being too dark whilst wet and look streaky as it was drying with the projector on
- Turned on my projector, put on Guardians of the Galaxy Blu Ray and was very impressed with the results. The blacks are very black and the whites are also spot on. I will post the calibrations for my projector as soon as I get a chance and this has made a big difference to the picture quality. Before painting BWU I was using Dulux Light & Space Pure White, this gave me a very bright picture but with reduced depth because the blacks were not defined.
I'm no expert when it comes to home cinema so don't ask me about levels, I just know that I'm very pleased with the results.
All the best with you project.
Hello again. Here are the settings for my Benq W1070. These seemed to work best with my BWU screen:
Preset Mode: User 1
Brightness: 51
Contrast: 45
Color: N/A
Tint: N/A
Sharpness: 7
Color: Temperature Normal
Lamp Power: EcoSmart
Advanced:
Black Level: N/A
ClarityControl: Noise Reduction 0
ColorTemperature Fine Tuning
Gain Offset
Red: 94 256
Green: 91 256
Blue: 98 256
Gamma Selection: 2.2
Brilliant Color: Off
Color Management
R G B C M Y
Hue: 44 50 50 50 60 64
Gain: 53 50 42 50 51 52
Saturation: 50 50 50 50 50 50
Aspect Ratio: Auto
Keystone: 0
Overscan Adjustment: 0
Digital Zoom: 1.0x
I'm set up in a smallish room with one window and very little direct sunlight. The room is painted cream but that doesn't seem to cause any problems.
Hi
A 'Panasonic DMP-BDT130 Smart Network 3D Blu-ray' and a 'Roku 2', direct HDMI to projector. I have different settings for 3D on my W1070:
3D
Preset Mode: 3D
Brightness: 51
Contrast: 75
Colour: N/A
Tint: N/A
Sharpness: 8
Colour: Temperature Normal
Lamp Power: SmartECO
Advanced:
Black Level: N/A
Gain Offset
Red 108 256
Green 83 256
Blue 93 256
Gamma Selection: 1.8
Brilliant Colour: Off
Colour Management
R G B C M Y
Hue 45 50 50 50 50 50
Gain 60 70 80 50 50 50
Saturation 50 50 50 50 50 50
Aspect Ratio: Auto
Keystone 0
Digital Zoom 1.0x
Hi there.
Very new to this projector screen business and have been reading about different paints etc.
I have a Benq1200 and It is going to be in a room which has white walls and a white ceiling.
Not ideal I know but unavoidable. Have made a screen and wanted to ask....
Is the paint mix you suggest suitable for this set up too?
Hope that you can help!
I havnt callibrated the screen but will look into that.
1 - 13 of 13 Posts
