1 - 5 of 5 Posts
So I went out and picked up Panasonic TH-46PZ80U. But now I need a Blu-Ray player to have some HD viewing pleasure materials.
What would you guys recommend?
And buying from where?
What price should I expect to pay?
I was thinking of getting the Panasonic DMP-BD35K for $299.99
Friend of the Shack
That's a find BD player. The only thing I might suggest is that if you dont' have HDMI audio, and you want to take full advantage of the lossless codecs, you'll need 5.1/7.1 analog outputs from the BD player. The 35 doesn't do that, but the Panasonic DMP-BD55K does. It's just their next model up, and I think it's somewhere around $350-400.
If you are currently successfully using HDMI for audio, go with the 35 you mentioned and enjoy!
Playback quality is larger the same on all blu-ray players, so get watever is the least expensive with the features that you want. In the next few years, we're going to see:
1) Player Prices Drop Dramatically
2) The Blu-ray format largely dies out because the masses adopt 720p downloadable video
3) Both
When any of those things happen, the last thing you're going to want is a $450 player sitting on your console.
1 - 5 of 5 Posts
