1 - 1 of 1 Posts
Hi,
I've BO 60.2 rl speakers. I listened the sound to be little hard and some lack of richness. I orded new caps, vishay 1822 and by bass 1830, 10 nF.
I also ordered new (old but never used from Hifitalo.com in Finland) loudspeakers. I think old voice coils had got some heat and there was some distortion in sertain freqs.
Old model is:
Woofer, LPT 130/25/120 FG, 8 OHM (*2)
Tweeter, Vifa D 26 TG - 05, 6 OHM
Hifitalo have following ones:
LPT 130/19/120 FG and Vifa D25TG-55-06
When I checked out the crossover, I noticed it wasn't same than in cervice manual. In attachments 1st is original crossover and the 2nd was inside loudspeaker.
Can anyone say, why there is different kind of high-pass filter-part of crossover: saving money or something else. The original connection is very easy to tune for crossover, so should I fix it.
Could someone advise me what to do with crossover. I have all caps, but there is 0.22 mH cole instead of 0.33. I suppose tweeter play through lower sounds than with 0.33 mH - but is there any meaning. I can't calculate the effect. If someone would have ideas how to make improvements to whole crossovers?
Regards, Lauri
1 - 1 of 1 Posts
