1 - 10 of 10 Posts
I'm looking at LCR speakers for a smaller room 3.1 setup that sound great, look good, and don't cost a bundle. Based on what I have read so far the cambridge s30 is my leading contender. I really like the dark wood finish the s30 has as opposed to the ubiquitous black boxes that mostly populate this price range. Is there anything else in the $200-300/pair price range that I should also consider?
Thanks for your input.
Welcome aboard.
That's a bit of a tough one, most of the speakers in that price range that I'm familiar with are basically black. I image the reason is to keep costs down.
It is pretty slim pickins, but those Polk RTi's look like another solid option to consider.
Thanks.
Welcome to the Forum. Have fun. Dennis
Thanks.
http://www.hsuresearch.com/products/hb-1.html Great finish (Rosenut) but a little over budget for the fancier finish.
http://www.theaudioinsider.com/manufacturers.php?mPath=13 Basic black vinyl but sounds awesome, personal favorite for bookshelfs. Planar tweeters and XBL2 woofers, can't go wrong.
http://www.audioadvisor.com/prodinfo.asp?number=MRBBX1&variation=PWAL Again alittle over budget but has great finish.
http://www.audioadvisor.com/prodinfo.asp?number=MOAVI1&variation=PWAL Right at budget with 3 different veneer choices.
HTS Moderator , Reviewer
Along with the suggestions already provided you should consider the Ascend Acoustics HTM-200 and the DefTech ProMonitor 800. Both are solid speakers and not your typical 'black box'.
You could also consider the EMP Tek E5Bi for $250 pr. The red burl is very nice for this price point and the Aluminized Poly-matrix Woofer with fixed phase plug provides a well balanced mid-range in addition to excellent high frequencies from the fabric dome tweeter. These speakers will take just about anything you throw at them without breaking up but you would definitely need a sub and a decent AVR to supply a little juice to the 85dB ([email protected]) speakers.
That red burl finish on the EMP's does look very nice, and they are on sale for $162/pair right now. Very tempting.
I wish the Arx A1b came in a similar finish. I've read nothing but great things about them.
The Mordaunt Short from post #6 is a good one to consider, and it is
made from the Cambridge Audio/Mordaunt Short family.
While some speakers can do some things better > the Cambridge S30
is still my favorite budget friendly speaker, for overall sound performace.
Good Luck with your choice and have fun!
1 - 10 of 10 Posts
