1 - 1 of 1 Posts
if you want to see what the sub can really do place it outside and the mic 3 feet away from it and measure and then you will have a bit better idea what the sub is doing without the coloration of the room messing up your readings.
However a lot of cheep mics may have a huge dip below say 30hz the cheep one I used to try and use before replacement fell off starting at 35hz by more then 20db just to give you a idea of some of the stuff that can be going on.
1 - 1 of 1 Posts
