1 - 11 of 11 Posts
Here is a picture of a stock preamp assembled from the kit.
Discussion Starter · #2 ·
You know me, I can't leave anything stock. So, here is the working side of what becomes a slightly modified version.
The chassis above I fitted into this custom cabinet. The side posts actually hold the top chassis on.
Next I built a fully custom version using point to point wiring but staying true to the schematic.
This custom chassis I mounted in a one off cabinet. The knobs I machined from billet aluminum.
The next mod I did was to replace the volume pots with stepped attenuators and replace the output caps.
Not one to let well enough alone, I re-stained the cabinet in a dark mahogany.
Even more mods. This time a whole new chassis.
The dual volume attenuators gave way to a stereo attenuator using 1% Dale resistors. I also added the Camille Cascode Constant Current Source (little PC boards). This is a high impedance current limit circuit for preamp and driver tubes, designed by John Camille.
And finally from the back.
You always have great mod threads. It would be nice to know why you decided on each change & what difference you perceived afterwards. Nice, neat work.
1 - 11 of 11 Posts
