What do you guys recommend? I have an Ep2500 to power them and want them to be as high output as possible with relatively flat response to below 18hz. This will be for 90% movies.
Thanks.
Thanks.
LLT would be the way to go I think. If you can afford some PRs you can get away with an easier build. You'd need 4 of them though.From what I have read, an LLT. I would like a box less then 10 cu/ft per sub if possible with no port noise above 15Hz. Any ideas?
WowQuick update. I was able to find a supplier that can source me 30" or 24" sonotube for $9.31/ft. Any designs that would transfer over to these tubes well? This might help with my sub WAF.
Thanks guys. This forum is excellent!!!!!:bigsmile:
Good point. :dumbcrazy:There wouldn't be enough room between the end of the port and the back of the sub.
Beleive it or not ...to me, is the easiest way to build a sub (I finished mine like a month ago) :bigsmile:I was able to find a supplier that can source me 30" or 24" sonotube ... Any designs that would transfer over to these tubes well? This might help with my sub WAF. :bigsmile:
Wait until she hears them!My wife just saw the bare sono in the garage. I don't think she was prepared.
