161 - 175 of 175 Posts
Hi Terry J, Very nice speakers you have there mate, what Model/Brand are they ?? I love my 2 channel as well but more into HT now...
As far as the speaker grill cloth, Scott from spotlight Geelong will ship it to you no prob's, $10au to ship AU wide I think...
Cheers Terry
Hope to see more pictures & idea's of what you end up coming up with mate...
If the local cannot get it, then yeah for sure on to scott
diy speakers, bit of a write up here
http://www.hometheatershack.com/forums/diy-speakers/19571-my-speaker-build-about-time-i-showed-you.html
actually, you may be able to help.
there is a dutch site that had a project very heavily into diffusion, heaps of pics. used tons of mdf to do the build.
this looks very much like it could be it, but randomly pressing buttons I have not come across the thing I am thinking of
http://www.soundscapes.nu/home.html
have you any idea of what it is I am looking for from my vague description??
Discussion Starter #162
Actually I am familiar with that web site, there is A link to it in this thread..
To make there QRD flutter echo diffusors they use A Spindel Moulder Cutter, The cheapest one we sell is made by Jet for around $2000au.. It makes it A lot easier than using A router like I did.. When making my Flutter Echo diffusors I used Tasman Oak as it is A hard wood and A lot easier to work when using A router to make precise accurate Vain/well cuts in these type diffusors ...
Cheers...
Actually I am familiar with that web site, there is A link to it in this thread..Cheers...
well blow me down! it is too.
Ha, this must have been where I got it from originally, how about that! I started a thread today on diy hoping people would know of it, and tonight we find it here.
Someone linked to the home page over on diy, it looked suspiciously like it could be the right site, but even with an hour clicking all the links there I still did not find it.
Why cannot my lotto picks be this serendipitous??
Just quickly glanced the thread looking for links, so not read it again properly yet. But I do recall you saying you found some good cheap plywood, do I remember right? Where did you source it from and is it exe?
Discussion Starter #164
One of the guys on that website went sick on the diffusor treatments lol, I think its safe to say he knows the importance of diffusion :bigsmile:
I think it was The same guy that posted on An acoustic's forum that he loves & recommends abffusors, absorbtion Diffusion in the one panel...
I was able to get hold of 2400x1200 sheets of 2mm & 1.5mm ply through Belmont Timber from memory, also I think I bought some 2mm ply through my local bunnings store, I paid around $13au A sheet I think...
Cheers....
HTS Senior Moderator
Last week I finally recieved the Quietel 130kg M3 fiberglass boards From CSR Bradfords, By adding Quietel it will extend the low frequency absorption of the rear corner mounted Broadband bass traps..
Unfortunately the Quietel only comes in A max thickness of 25mm (1") 2400x1200 x2 per pack :crying: as apposed to ultratel 48Kg M3 50mm 2400x1200 x3 per pack..
I just doubled up the Quietel to 50mm and added it to the rear of the existing 100mm 4" of Ultratel, so making A total of 150mm "6" thick bass traps for the rear wall corners...
That's very interesting Jason..
What's the difference in density between the Quietel and the Ultratel?
I'm using 6" thick Supertel for the rear traps..
What improvement/changes did you notice in the low frequencies with the Ultratel added?
Also I changed all my first reflection absorption panels (ultratel) from 50mm 2" to 100mm 4" thick
so as to obtain more "even" absorption for Mid & High frequencys, Floyd Toole's new book points out the importance of this..
Also interesting..What improvements did you notice with the 4" panels over the 2" ones?
Discussion Starter #167
As far as going from 2" ultratel with 2" air gap to 4" of ultratel for my first reflections the absorbtion cf will be more balanced for Mid & High frequenceys as Apposed to 2"...
Cheers....
Hi Prof, Supertel is 32Kg m3/ Ultratel is 48Kg m3 or 3pcf( Same as owens corning 703)/
& Quietel is 130Kg m3 (oc 705 is 90 or 6pcf...
Here is A link to CSR bradfords Glass wool specs
http://www.bradfordinsulation.com.au/Products/Commerical/HVAC.aspx
Hope this helps
Cheers....
Thanks Jason..
Hmm...It looks like the Quietel is significantly more dense than the Ultratel and a lot denser than the Supertel..
I think I might try and pick up some Quietel next time I go to Adelaide..
Discussion Starter #169
Hi Prof, I should point out that The density of Quietel is better suited to bass traps "NOT" first
reflections & Ultratel is best suited for first reflections..
Personaly I would go with Ultratel due to being very good for both applications..
I used the 2" of Quietel & placed it behined the 4" of ultratel rear bass traps to help absorb lower in frequ...
Hope this helps,
Cheers....
That's what I'm planning on doing as well..if I can get hold of some of the Quietel..
I'll leave the reflection point panels as they are for the moment..
Hey Jason ... wonder if you could make some suggestions as you have clearly invested alot of time on this subject
Theatre is at rough-in stage but planning for acoustic treatments ... room size is ~ 14' X 23' ... 7.1 surround using Axiom M80 LR, EPIC 600 SUB, VP150 center and 4 X QS8 surrounds ( another sub to be added later on if needed )
I had planned to put OC703 corner wedge bass traps on screen wall, linacoustic on rest of screen wall and for the first 4' of the side/rear walls and empty space above that covered with a AT fabric like GOM or Dazian
my questions for you are:
- would you recommend using diffusors above the linacoustic on the side/rear walls ?
- if yes, then due to the linacoustic being 1" thick would it possible to use strips of hardwood to create the channels for the diffusor and glue to the drywall to save space ?
- if I build diffusors with a max depth of 1", would that be beneficial ? ( could go deeper on rear wall ... maybe 2" deep ) ... reason I ask is all your diffusors seem to be much deeper
- if all the above works out, I had planned to cover all the walls with a AT fabric, do you see any problem covering a diffusor with a AT fabric ?
I am very limited on the side walls due to the door location ( support post restricts entrance door location to be very close to side wall )
Thanks for any suggestions
Discussion Starter #172
Hi Steve,
Diffusors inc Flutter Echo Diffusors (around 25-30mm thick) will work fine on the rear sidwalls, you can place them over semi riged fiberglass or absorbtion substrait, but small cutouts in the deeper wells of the diffusors are needed as well as random spacing with an air gap behined the diffusors to allow for the lower frequencys to be absorbed below where there usfull diffusion stops...
Flutter Echo Diffusors can be mounted to small strips of wood that are attached to the drywall.. I have never cut varying depths of wood strips/vains based on QRD prime seed to form wells for diffusors, but they would need to be mounted to A hard backing such as wood and must be built very precisely to perform as designed....
The main thing to remember with QRD diffusors is the deeper the wells the lower they will diffuse
the larger QRD's I made are prime seed 13 & 7" deep but I chose to placed them on the back wall next to my rear bass traps...
I would'nt recommend covering diffusors with any thing due to affecting there ability to diffuse optimumly....
A good rule of thumb for the most important areas to cover when it comes to room treatments for A Home theatre is to first treat the 4 corners with bass traps either with super Chunk style or 6"thick floor to Ceiling if possable Also the first reflection points inc the Ceiling..
Then you can move on to treating the rear wall with absobtion directly behined the rear seats and diffusion on either side closer to the corners, Diffusion on the rear side walls also placing Accoustic insulation batts in the Ceiling cavity above the theatre can aid in low freq absorbtion...
It is important to not over treat the room with two much absorbtion as this will deaden the room to much, rather its A fine balance of Absorbtion reflection and Diffusion analizing the room with mic & Acoustic software then futher tweaking/refining untill you get A good balance & even decay time...
Hope this helps
Cheers Steve...
Hey Jason ... thanks for the response
Due to WAF and wanting to have the fabric theatre look where all walls are covered in fabric it looks like diffusors will be out for me then if they cant be covered with fabric
The ceiling will be R19 batt/rsic clips/hat channel/DD/GG ... walls staggered stud/R13/DD/GG
If you look at the drawing I can only fit corner bass traps in the front of the theatre room as the rear of the room has 2 doors to deal with ... I can probably put 2" or 4" insulation on the rear wall though ... maybe even 6" if that will help with bass trapping ??? - Should I just cover the entire rear wall then with absorbtion or just where the first reflection point software indicates ?
I had also planned to put a sub built into my riser ( 4 X 12" Shiva drivers firing to the back wall - drawing in my build thread http://www.hometheatershack.com/forums/home-theater-design-construction/18075-steves-basement-theater-construction.html )
Also I plan to build a coffered ceiling with Linacoustic in the areas of first reflection as my center channel will be mounted in the soffit
Discussion Starter #174
Hi Steve, This looks as though its going to be an Awesome HT mate, I could only wish for A room this size to Build A HT..
You could use Polycylindrical diffusers "Polys" on the rear side walls and paint them the same colour as your Acoustic fabric or put acoustic fabric over them, they can be fairly easy to make with thin Ply, also I think Bryan GIK sells polys...
you could put some form of absorbtion 6" thick semi rigid fiberglass on the back wall placed between the Ceiling and rear wall thus providing an air gap to boost the lower freq absorbton, or placed against the rear wall..
I found the more Subwoofers (I have 4) which in turn brings up the LF sound pressure the more bass traping I needed to try and tame the LF decay time/ringing..
Also the down side to: more rigid you make your side walls IE:adding 2/3 layers drywall) the less LF they absorb so the more important Acoustic treatment's become, same goes for concrete walls...
Cheers Steve,
RE: Jason...
Hi All. I have been reading and re-reading this thread lately and there is some great information in this thread. I know this is a couple of years old now but i would be keen to hear where you are all at two years plus down the road. Changes made ... what you would definitely do again and what didn't really work out. The reason for these questions is because i am about to go down the same route with my room. Thanks a heap. cheers j
