1 - 1 of 1 Posts
Hi
Sony STR GX 69ES mid 80's. Works excellent , but the plastic power button on front broke. It had a plastic hinge, which failed. I fished it out, without having to undo about 3 circuit boards. I believe it is a momentary switch that powers a relay to come on.
I can stick my finger in the hole and the tactile switch works perfect. I thought of a spring or even foam backer rod on the plastic button, but there is little purchase area for that. I thought maybe a new switch.to fit the hole, but that means removing circuit boards and ribbons that are likely brittle. And we have no electropics parts supply store near by.
Switch is 21.8 5mm x 11.8 mm. Will try to post photos. Thanks
1 - 1 of 1 Posts
