Bruce,
I know you are pretty familiar with the mobilepre and I was wondering if you could help me with the initial loopback test. I have read so many methods that my head is about to explode :gah:
Would this be the correct method for making the calibration file?
1.) Connect channel 1 out to channel 2 in, using the 1/4" connections for the loopback
2.) Use a mono 1/4" to RCA adaptor to get from the MobilePre 1/4" output to the input of the processor.
3.) Use "Y" adaptor to feed both channels of the processor with the mono out from the MobilePre
Is there any advantage to splitting the signal to use 2 RCA inputs vs just using one? Which line-out would I use (1 or 2) once I make the calibration file? I would assume CH1 but that is the L-channel and from what I've read you do not use that one.
Thanks for the help in advance!
-Jonathan
-Jonathan
