1 - 10 of 10 Posts
I already have powered speakers, so I either want a receiver with pre-outs or a Pre-amp seperate.
The budget is about $500 maybe more if there is nothing at that price range.
Also, having HDMI switching is a must.
Anything in this price range?
Hello,
Something like Onkyo's TX-SR706 B-Stock from Accessories4less would fit the bill offering preamp outputs and HDMI Switching and also gives you THX Certification and Audyssey MultEQ.
Here is the link:http://www.accessories4less.com/make-a-store/item/ONKTXSR706BLK/Onkyo/Tx-sr706-Thx-100w-X-7ch-Theater-Receiver-Black/1.html
It retails for 900 Dollars and is available for 429 Dollars.
That will be one of the cheapest choices as very few to almost none of the entry level AVR's offer preamp outputs. Another choice would be one of Harman Kardon's Ebay Store AVR's with preamp outputs. However, I think the Audyssey MultEQ and THX Processing makes the Onkyo tough to beat.
Cheers,
JJ
If you can stretch just a bit further Emotiva have a new SSP which is the UMC-1 and it comes in at $699 but it looks like it is a bargain considering what you get, there is a thread located HERE
Just another option to consider :)
Discussion Starter #4
I'm well aware of the Emotiva, but it's out of the price range. The onkyo 706 looks good at $429 certainly better then the $799 retail.
well you cannot go wrong with an Onkyo as they do offer very good performance for not much outlay, I cannot think of another budget processor unless you go S/H....
Yup, I agree the 706 is a great choice. However for the $50 more it costs to get into a 707 that would be a much better choice.
Discussion Starter #8
Hello,
Cheers,
JJ
I bought it, thanks for the tip! :T
Hello,
Enjoy. I really think it will work out quite nicely for you and it was a great deal. If you have never used Audyssey or other Room EQ systems before, I really think you will be impressed. And if you do not like it, it can be turned off completely.
Cheers,
JJ
1 - 10 of 10 Posts
