1 - 20 of 31 Posts
Can't get REW to work properly today. Wont produce any output using the same settings and connections as yesterday. Check Settings gives <47dB output despite plenty of sound at the mic. Volume Control settings are correct. Check Settings stops after about two seconds of turning it on. I have restarted the program twice.
Can you show us a jpg of your REW Settings screen and of your Windows Playback Mixer?
We also need to see what sort of error might have occurred. There will be a log of what happened in the debug files. To locate those, open the REW Help / About box to see where your home directory is (i.e. C:\Documents and Settings\yourname). The log files are stored there.
Look for files called roomeq_wizard0.txt, roomeq_wizard1.txt etc. Open each file in any text editor (e.g. Notepad) and see if there are any error messages. A new file is created each time REW is started, the last 9 copies are kept in a rotating list.
What does the error (if any) say about what's happening?
This may be a sound card driver issue. I see behavior like this on an XP system with Soundblaster SB Live. If I go into Control Panel -> Sounds and bring up the Sound control, under either Sound or Voice I click on the Volume button under Record, I see a choice of Mic, Line In, and S/PDIF in. If I click away from Line In to Mic and back to Line In, REW can again see the sound input.
Bill
Posted via Mobile Device
REW doesn't appear to see your soundcard.
Can you post your Settings page, or at least tell me what you have selected in the Input and Output Devices section on the Settings page?
For example below:
You can see the soundcard is selected and the line-in and line-out is selected.
Text Blue Font Line Screenshot
This sound similar to something I've run into:
Conditions under which the problem occurs:
1) Set up REW using external soundcard (Creative X-Fi 5.1). Do measurements .... all works fine.
2) Shut down laptop and reboot without the sound card attached.
3) Shut down system and re-connect Creative soundcard for another REW session.
At this point REW seems to lose knowledge of the external soundcard. My work around is to re-select the soundcard in settings under 44 KHZ. (both input and output), then select "speaker" and "line in" under 48 khz.
Then it works. I've run into this every time I've done 1 - 3 above. It's like something gets reset after starting up without the sound card attached.
Don't know if this helps or not, but wanted to let you know.
Rog
Brucek:
I would post the screens if I knew how to shrink the size of the screen captures.
Output: SoundBlaster/Speaker
Input: Soundblaster/Line_in Level=1.0
Levels: Use Main
Playback and Recording levels for Volume Control are all full. WaveIn is LineIn checked.
This thing is getting more jumpy. I just had it working twice and the third time it lost Right output.
Brucek:
Most generic way is to open MS Paint (probably in Programs->Accessories)
Paste your screen capture in there.
Click Image->Resize
A window will open where you can shrink the size as needed.
Save the file.
Discussion Starter · #15 · (Edited)
Reducing those attachments to 20 kB with Paint makes them too small. Please look at previous post where I listed the settings. It isn't the settings anyway.
I just took two good measurements starting from scratch and the third failed. No change of settings, only a move of one bass trap. Seems like either the software has a bug and I need to re-install; or the sound card has a bug and I need a new one (recommendations?); or Windows Volume Control is flaky.
Any suggestions from an experienced REW person? Please help!
PS: Details of Volume Control:
Play: Mic, LineIn, CD on mute; Play, Wave, MIDI on full volume
Record: All at full volume, LineIN selected
Discussion Starter · #17 ·
Sorry, I meant to type "any experienced REW person". It is clear you are the "Pro-from-Dover" (M*A*S*H) on this forum and I appreciate all the help you have given me.
Yes, the LineIn is muted. Since REW is acting so flaky, I will re-install the REW and Creative software. If the hardware is flaky, how will I determine that? If I need a new box, do you have a suggestion?
Thanks
Bob
I think you can rule this bug out as being in REW - too many users over too long.
My first thoughts always go to the cabling and connections being suspect.
Once a card has been working for a while, they're pretty reliable. If the card plays music without being flaky, it's probably OK.
Could be drivers, but that's usually a go, no go situation.
I would reload Java and the Creative software, and also re-check the cables and connections.
· Elite Shackster
Another way to reduce image size in paint is to do it with the image attributes option, and change the size to the max allowed. This trims the image though, it doesnt scale it, so you have to ensure the data you want to show doesnt get trimmed. This method doges lost image clarity due to scaling. Its not great if you use a very high resolution though.
Discussion Starter · #20 ·
Still having erratic REW performance.
I can get 2-3 good measurements and then the level drops off to less than 45dB. Nothing seems to get it back but some time (hours).
I have re-installed REW; checked all connections; re-booted the computer; ran REW with and w/o the SoundBlaster plugged in; carefully set all settings each time; and prayed to all Shack Moderators.
Today was a little different and maybe instructive: Here are five graphs in chronological order, just a minute or two apart. It seems to me that despite changes in moving a speaker, moving a trap, etc., that the noise level is increasing as the session goes on. I don't trust any but maybe 1 and 2. After 5, there was no level to measure.
Hopefully someone will say AH-HAH! and see the light (er, sound).
1 - 20 of 31 Posts
