Anyone have suggestions on build plans for bookshelves that have very decent SPL for their size? I already have a sub (with more on the way). I'm more interested in SPL than SQ. It would be nice to keep the price around $300 or less per speaker.
Once Audio Karma accepts me, I will view the information. Thanks for the heads up as I have not heard of these yet.Can hardly beat the AK Indignia.
http://www.audiokarma.org/forums/showthread.php?t=160535&highlight=Indignia
what is "crossover loss"? The 1/5th of an ohm resistance from an inductor?At the risk of over-simplifying a more complex problem: wouldn't the equasion for "high efficiency bookshelf" basically be "high efficiency driver (full-range to avoid crossover loss) combined with a large enclosure (likely ported) to provide as little resistance as possible"?
Tweeters are generally padded down because they are inherantly more efficient than woofers. There are some efficient full range drivers, but they have rediculously low xmax and therefore cancel out any gains obtained from the efficiency gains.Actually: I was thinking that since not all drivers are equally efficient at a given range, that there had to be equalization in the crossover to "driver match". Since that cannot introduce new power (increase the power going to the less effcient driver), it must reduce power to the more efficient by converting it to heat: hence "loss".
But I've not built a crossover: perhaps I'm missing some basic physics. How do you prevent one driver from being unequal to another without selective reduction in the power flowing to it?
Agreed. I know of no full range driver except maybe the Infinity MRS that is capable of high volume. Full rangers are more suited to surrounds IMO. You need less SPL in that application.Tweeters are generally padded down because they are inherantly more efficient than woofers. There are some efficient full range drivers, but they have rediculously low xmax and therefore cancel out any gains obtained from the efficiency gains.
Multi-driver is the way to go if youre looking for SPL.
The bigger the better also, but if you're using a sub you can sacrifice extension for efficiency...
