1 - 4 of 4 Posts
· Plain ole user
Your thread has been moved to the Hitachi forum to maintain forukm organization and to make the information easier to find.
I have not used it. Why do you think your original is bad? How have you tested it?
Thanks for the quick reply. The flyback has A small pin hole in it,therefore arcing to the chassis.OEM part is NLA as you probably know.Do you have a good used one? Thank you for your time and effort.
· Plain ole user
I do not have a used one. I have had very mixed results with the ASTI parts, but some work fine. You have little choice but to try it if you cannot find a good used one.
1 - 4 of 4 Posts
