1 - 3 of 3 Posts
I have been working with REW for a few days and have some questions even so I did some searching.
When I calibrate the soundcard (soundblaster live 24bit external) does it matter if the
c-weighting box is checked or unchecked in REW?
The results I have gotten do not seem to be right in that the subwoofer frequency response rolls off dramatically below 40 hz. I have an IB with 4 MJ-18’s soon to be replaced by IXL-18.4s so it is pretty impressive even without equalizing.
I have a Galaxy cm-140 meter and I have loaded the calibration curve. Should I use it
C-weighted or A-weighted and should I check or uncheck the REW C-weighted box? My sweeps have looked low using the meter A-weighted and REW C-weighted unchecked.
I read in another thread to press the Apply Windows button to recalculate the frequency response with a calibration file. I do not know where that button is and the having the calibration file loaded or unloaded in the settings makes no difference to the response.
I am also getting warnings about the impulse response but I think it may be related to what I am doing wrong here.
No..........
Measure an RCA cable connected from line-out to line-in instead of the SPL meter connected to line-in and the subwoofer connected to line-out.
It should measure a flat response (with soundcard file loaded, and meter cal file cleared and C-weight box unchecked)................
Set the Galaxy to C-Weight.
Leave the C-Weight box unchecked in REW. The cal file over-rides it at the cal files frequency extremes.
This is only required when you change cal files and want to recalculate the frequency response graph from the impulse response rather than take a new measure. The Apply button is in the IR Windows pop-up.
Thanks for the help.
I had the meter at A-weighting and the REW box unchecked and was getting a low response. When I switched the meter to C-Weighting and checked the REW box the response looked high. I hope I get to work on it some more tonight.
Thanks again.
1 - 3 of 3 Posts
