1 - 5 of 5 Posts
Is there any way to set calculated time window and remove the mic distance before plotting frequency response? THX
You can use the Estimate IR Delay feature in the SPL graph controls to eliminate pure time delays in the measurement (such as the time of flight to the mic and delays in processors), though time delays only affect the phase response, they don't affect the SPL response.
No, I'm referring to this:
There is more info here.
Note, however, that these features will only work on measurements that have impulse responses, either measured by REW or by importing an impulse response from another measurement package. They are not available for measurements imported from text files.
1 - 5 of 5 Posts
