Hi Guys ,
I should be getting my calibrated ecm8000 from cs in a couple of days
i also own a non-calibrated ecm8000
and i wanted to know if its possible to semi-calibrate my old ecm8000 with the calibrated one
of course it won't be the same as professional calibration but it should bring it to a semi-calibration level right?
has anyone tried it?
im planing on doing it at home ( regular not-treated room ) using white-noise
and a tripod or something to keep the placement as close as possible when i switch between the mics
should i gate the measurment? to avoid as many reflections as possible?
thanks in advance ,
gutz
thanks in advance ,
gutz
