Hi there,
I used REW before on a PC based system at a friends studio and everything went fine.
Im currently in the process of setting up a different studio which is mac based (Leopard 10.5).
We are restricted to a Presonus Firepod at the moment but I thought that should be a problem. However, when calibrating the soundcard a few problems occur:
1) A direct loop from line out to line in results in a loss of almost 10dB (cable is fine) which has to be compensated using the line trim
2) The result of the calibration looks quite odd and I wonder where the problem might be (see screenshots). This cant be right.
Can anyone give me a hint where the problem might be? I tried the calibration with and without using the line trim with the same results.
Any help is appreciated.
thank you
studiomann
thank you
studiomann
