1 - 4 of 4 Posts
Hi everyone. I am having two custom boxes built for the Mach 5 FTW 21 drivers. However my question is to make them with 2 pin or 4 pin speakon connector plates? All of my speakon cables are 2 pin. And I've heard 4 pin speakon cables are rare. However, I've also heard 4 pin speakon connector plates will work with both 2 pin and 4 pin speakon cables. I just want to make sure this is true before I order a set of 4 pin speakon connector plates from parts express.
Yes. The pins +/- on the 2 pole SPEAKON are aligned to the 1+ 1- of the 4 pole.
As an option: You can run 4 conductor wire to the first speaker and use 2+ 2- on a 4 pole SPEAKON as a loop out/through to the second speaker carrying the other channel. This can save you from running two pairs or "home runs" to each speaker if you choose.
Sorry for the late response, just now getting involved in HTS.
4 pole speakons are most common, they let you run bi-amped systems on one connector.
A 2 pole female will mate with either a 2 or 4 pole male, but a 4 pole female will only work with a 4 pole male.
I'm in the process now of changing out some 2pole connectors for 4 pole, on a set of wedge stage monitors.
If u buy any pre-made cables or eqt with speakons, always check. But they are great connectors.
KAYCEE
1 - 4 of 4 Posts
