Hi, How are you? I have a RCA RT2911 1000w Home Theater System. I'm not satisfied with its subwoofer. So I would like to replace it for this 360 RMX Samsung PS-WZ510 subwoofer (3ohms). The RCA subwoofer is 210 RMX with 3ohms. Could I damage the Home Theater by running the samsung subwoofer?
Thanks
Yes, technically, you can replace the one for the other. I wouldn't expect too much of a performance increase; both are passive subs and both will get their power from the head unit.
Honestly if you're looking for better sound; you should start looking into some kind of and AVR/speaker package. Onkyo and Denon both made a good starter system. The advantage to these systems is that they are modular and you'll be able to upgrade parts as you see fit.
If you're somewhat satisfied with your surround system, and upgrading the sub is most important to you, try a powered sub. If you buy a substantial sub, you can still use it later when upgrading the rest of your system. Since your receiver has no LFE, sub out, you'd need a powered sub with speaker level input. you can find basic connection advice several places, like http://www.crutchfield.com/S-2eJQwpqxWWE/learn/reviews/audio_explorations/2007/0327.html
Discussion Starter #4
Thanks for your recomendation. I would try later on to buy an AVR System. I was looking on the internet for a better sub, and i found this one which i think is better than the samsung one. Should I replace it for this one. Or I should stay with the samsung one?
http://www.amazon.com/gp/aw/d/B005CKN00U/ref=mp_s_a_1_2?qid=1422490681&sr=8-2&dpPl=1&dpID=41X5UT9dzwL&ref=plSrch&pi=AC_SY200_QL40
Thanks
Look for a sub that has both RCA and speaker level inputs on the back. It will have a power cord also. You should also see a dial or switch labeled "crossover". You'll be able to use it now and later when you upgrade the receiver.
Pioneer makes a very good cheap sub
http://www.pioneerelectronics.com/PUSA/Home/Speakers/Subwoofers/SW-8MK2
You can find them used or the first version (not MK-2) cheaper/clearance
Good luck and happy hunting!
