1 - 5 of 5 Posts
Good evening
I want to build 2 X 12 inches subwoofer for my home theater. I am looking to build a sub that will be very tight, fast and articulate with its bass response that would provide a great movie game and musical experience!
my listening preferences are as follow: 5% music, 45 % games 50% movies.
Room is 13 X 10 X 8 and sub will be driven by 2 behringer EP4000.
MY current speakers are Behringer B212XL .
Any recommendation in term of driver and cabinet size ( 14 X 14 X 15 would be a nice footprint if achievable) and amount of polyfill i should stuff the cabinet with
Alain
Super Moderator
What is your budget?
Fast and tight can be done by any size subwoofer. If wanting a small subwoofer and enough SPL than you will most likely need a high quality driver with a powerful amp. Many different choices are out there. Just depends how much you want to spend.
Hi
In term of amp i have 2 EP4000. budget wise hummm around $600 to $800 each since i want to build 2 ....
2 of these Dayton Audio UM12-22 12" Ultimax DVC Subwoofers will do the job nicely - Parts Express also sells easy to assemble cabinets for them OR there are several reviews with different build projects....
Ultimaxx are very good subs - I have 2 of the 15's in my home theater ...
Hi
Sounds like plenty of amp and budget, if anything, too much amp for some 12s >:)
1 - 5 of 5 Posts
