OK. I had everything going great for the last few days, then, a friend of mine disconnected the souncard from the computer while REW was running and it does not work now. The right meter does not go into any of the lighted areas no matter what I do. I recalibrated the soundcard and now it is screwed up again. When I measure the soundcard, the graph is way upon the left side and flattens out as it goes and then drops off. I get sound out and can adjust the sound out, but I do not get any noticable signal on the right meter. I get a graph way down in the db level on the graph, so it must be picking up signal, but the graphs are off and it is not functioning like before the usb cable was removed while REW was running.
Any thoughts?
Thanks,
Robert
