I must be missing something simple here. I added a second tc2000 15" to my system and am driving it with an ep2500 bridged. For some reason I can't get the second output to work from the BFD. I currently have both engines coupled but that shouldn't matter. I can only get output from the number 1 side. My first sub uses an adapter to 1/4 inch or rca, and on the second sub I have an xlr cable to 1/4 inch. I even tried connecting both different connectors to the same side but it seems like the xlr takes precedent and I lose signal on the first cable. But if I connect the xlr to side 2 no signal is sent to the ep2500.
Is there some way to turn on or off the 2nd set of outputs on the feedback destroyer????
confused....
confused....
