just bought a single sdx 10 which will run off 300 watts rms at 4ohms, can anyone suggest an optimum enclosure size and type? I can go ported or sealed, huge or tiny, just want something that works well.
If you are only running 300 watts you can probably get away with a little larger ported box. CSS recommends a 3" port. I advise against that small of a port for any driver over 6.5" though. Dont forget to use a subsonic filter when running a ported box. Good luck
