1 - 4 of 4 Posts
Center channel speakers recommendation?
My setup:
  • 25" x 15" x 9" room
  • 5.1 home theater system
  • Front Left/Right - Canton Quinto 510
  • Center - KLM unknown model
  • Surround Left/Right - Canton GL 260
  • Subwoofer - Polk PSW110 (want to replace with SVS PB-1000)
I am a novice in home theater setups. I inherited the old Canton speakers from my Dad so I did not spend any money on those.
When running sound tests like when setting up the receiver, the center speaker sounds distinctly different from the left and right. So I am investigating whether I should replace the center speaker with a speaker that's a better timbre match with my left/right speakers.
I contacted Canton and a rep recommended the Canton GLE 456. It's $400 and seems very expensive.
Do you have any recommendations for a cheaper solution?
Is there a more affordable Center Channel speaker that would be a good match for the Canton Quinto 510's?
Should I replace all 3 front speakers, and with what?
Thanks in advance.
1 - 4 of 4 Posts
