i was given a pair of cerwin vega sl-36 bins from a friend that bought an old nightclub.
they are big and old and need an insane amount of power to move them in the current cabinets. When properly powered they just about took the windows out of my living room, i tried them on a yorkville ap4040 bridged down to 2400w @ 8oms continuous. However at a middle and lower end volume range they really don't do much and they dont sound all that clean.
both drivers are in amazing shape and have no rub so i would like to give them a new life, the cabinets may be turned into marshmello roasting firewood.
I was just wondering if anyone has tried an older 18" cerwin vega driver in a smaller cabinet, something that does not require as much power. and hopefully play a little cleaner. I have a mackie plate amp that i could use, its 500w so i could use that or buy something bigger.
i have the specifications and am currently reading through the winisd walk through and attempting to make that work. I guess im just unsure if they will work in anything else since the drivers were designed to be horn loaded. But if anyone has any suggestions or comments i would like to hear them
Cerwin Vega 189SE Driver Specs:
FS (Hz) 30.5
QTS .227
QES .241
QMS 3.86
VAS (liters) 244
SD (sq m) 1065
RE (Ohms) 5
VDD (ccm) 555
Xmax (mm) 5.2
PE (watts) 400
LE (mh)
EFF (%) 2.8
EBP(Hz) 126.6
Frame Diam 18
FS (Hz) 30.5
QTS .227
QES .241
QMS 3.86
VAS (liters) 244
SD (sq m) 1065
RE (Ohms) 5
VDD (ccm) 555
Xmax (mm) 5.2
PE (watts) 400
LE (mh)
EFF (%) 2.8
EBP(Hz) 126.6
Frame Diam 18
