1 - 10 of 10 Posts
Hello.
I have recently purchased the Cerwin Vega CVHD 5.1 systems and I was trying to set it up together with my Onkyo 606 AV Receiver. The problem is I never managed the subwoofer to work.
So, I have CVHD-12S powered subwoofer that has:
1) HI-LEVEL INPUT L+R connectors + and -
2) HI-LEVEL OUTPUT L+R connectors + and -
3) LINE IN (for RCA jacks)
4) VOLUME control
5) LOW-PASS FREQ control
6) 0/180 PHASE switch
7) STANDBY indicator red/green
here is the picture of the connection:
after it did not work with the a/v receiver, I tried to test just the subwoofer. What I did was I connected my MP3 player to the LINE IN and that, as far as I understand should make the subwoofer produce the base sounds. Which it did not.
after that I tried to connect 2 speakers to the HI-LEVEL OUTPUT and it should have sent the sound to the speakers and subwoofer but none of them produced any sound.
The STANDBY indicator shows green, meaning that the sound goes in properly.
I tested all the cables and they are alright. Again all 5 speakers work perfectly from the AV Receiver but as soon as I connect them to the subwoofer, nothing happens.
As far as I understand, connecting the MP3 player to the LINE IN should make it produce the base already which is not happening. Am I right? Do I know for sure that this is the faulty subwoofer?
Thanks for your help
Can you verify that the "Sub Out" is working on the 606? Last night I watched "The Incredible Hulk" DVD. No sound from the Subs. I checked all my settings and they were good. The DVD's default sound was 2 channel stereo. I changed it to 5.1 and all was good. My point is to check everything there is to find out where the problem is, don't assume it's the sub that's not working.
Thanks for the reply.
1. I tried the audio settings from 606, then Audisey setup with the microphone and that did not find the sub. No sound from sub. On Bad Boys II all 5 channels worked but sub.
2. I tried to connect the MP3 player to line in of the sub and still no sound.
3. The sub speaker never produced any type of noise -- background or when I switch the songs on MP3 player or when I turn it off. Not a single beep.
I am pretty sure the sub with just MP3 player plugged into the sub's LINE IN should make it produce base.
yep, tried that as well already:
606 speakers (Front Left, Front Right) output > sub HIGH LEVEL INPUT
sub HIGH LEVEL OUTPUT > speakers
sound is going to the speakers but the sub is sooooo silent
1 - 10 of 10 Posts
