1 - 2 of 2 Posts
Hello,
as a first build, I would like to put together a subwoofer. I came accross 2 good looking CV subs, but cannot find any information about them needed to calculate the box size. Do you guys have any idea where I can find this?
I tried asking it to Cerwin directly, but no response. Google didn't help me a lot either. For a first build, I also don't want to buy a tester (which is 100 USD and up) to test all the values. I would like to keep it low budget, if the wife likes it, I might get some buyin to do some more building:boxer:
thanks!
It would appear that it will be hard to find T/S specs. Such as others have stated on DIY audio you could use a WT3 tester to find specs. I have seen also the recommendation of 4.5cuft 32hz. Not really that helpful at all.
1 - 2 of 2 Posts
