Chane 3.2 Home Theater System Review
9112 Views 0 Replies 1 Participant Last post by  Peter Loeser
Introduction
Craig Chase and Jon Lane are long time friends of the Home Theater Shack, and have been working hard this year to release new and updated HT and Hi-Fi products under their new brand, Chane Music & Cinema. Among those are the Theater Ten monitor and SBE-118 sealed 18" subwoofer. These models are geared toward providing low-distortion, and high output from even modest home theater receivers at a relatively low cost. The Theater Ten is a somewhat unique combination of pro monitor design and aesthetics and high fidelity home audio sound quality. The passive SBE-118 takes advantage of a huge 18" driver in a relatively compact sealed cabinet. As reviewed, this 3.2 system retails for $2400 and has the potential to be an incredible value in home theater performance.
Design, Build Quality, and Aesthetics
I'll start with the Theater Ten. At first look, it appears to be a pro monitor designed for stage or studio use. The wedge shape and heavy-duty grill give it that rugged look you would expect from pro gear. Chane has combined a horn-assisted compression driver and a 10" woofer in a ported cabinet to produce a high sensitivity speaker for clean and dynamic performance. Although it is not necessarily a lightweight, it is relatively compact considering the size of the drivers used. The Theater Ten's MDF cabinet is finished with a black textured PVC coating and a steel grill, both offering excellent durability. The SBE-118, like the Theater Ten is designed for performance and value. The cabinet is made from 1" thick MDF, with a 2" thick front baffle. The SBE-118 does not come with a grill. The enclosure is covered with four coats of a smooth semi-gloss black finish. The rear panel has a single set of binding posts for connection to the amp. The driver is a proprietary 18" long-throw woofer with power handling capability of up to 1000 watts. It also features high sensitivity, providing some flexibility for amp selection (although the Dayton amp was included with this package).
Both the Theater Ten and the SBE-118 are rock solid. The cabinets are heavy duty and more than sturdy enough for typical home theater use. These could easily take a fall off a shelf or speaker stand, or maybe even down the stairs. (don't worry, I did not test my theory) It is clear that Chane takes pride in the build quality of their products, and these particular units appear to be very well constructed. The only minor issues I noticed were a couple little chips in the finish near the corner of a Theater Ten. They are hardly noticeable, and may very well be a result of packing/shipping.
Compared to most speakers you would expect to find in a home theater, these have a rather utilitarian appearance to them. The design of the Theater Ten, with its textured finish and steel grill, is not what I would call elegant, but still very clean and even a little intimidating (in a good way). I would say that steel grill is my favorite part of the overall look of the speaker. It's different, but it works. I've also had a couple friends comment that they like the looks of them while they've been set up in my HT. The SBE-118 is plain looking with its smooth matte black finish and exposed driver. I personally don't mind looking at a big woofer like this, but some (i.e people with kids) may prefer to have some form of protection in place. This sub is about performance and value, so the simplistic design and no-frills aesthetic are no surprise. Chane has done a nice job of making these components look good in a home theater setting without adding unnecessary decorative elements.
Setup and Operation
My goal for setting up the Theater Tens was to place the HF driver of the left and right channels at or close to ear level, and to place the center channel directly below my display. On a pair of stands I already had, the height of the left and right speakers was spot on. They are 1/4 of the distance in from my side walls, which puts them just outside the edges of my display. The center channel is just below my TV, horizontally oriented. This is pretty standard, and basically mimics the placement of my personal speakers, so it is familiar to me. Unfortunately, my room does suffer from poor acoustics in some areas and the Theater Ten was not immune to this. I spent a bit more time arranging the subs. Dual subs can do great things for the bass response in a room, but placement is still critical. My HT is definitely a case that benefits from properly placed dual subs. After experimenting, measuring, and listening with the subs at several different locations, I ended up with one in the center of the front wall, and the other centered on the rear wall. This meant the center channel had to sit on top of the front sub, which still worked out ok for the review period. This provided nice even response at the MLP below the 80Hz crossover point and solid response down below 20Hz, with about a 10dB drop from 20Hz to 10Hz. Not bad at all. Additionally, there were very few noticeable variations in the sound of the bass as I moved around my seating area.
Although the subwoofer amp is a Dayton Audio product bundled with the Chane subs, it is a critical part of the setup, so I want to discuss it briefly. The SA1000 is purpose-built for subwoofer use. It has multiple RCA inputs and two sets of speaker level outputs. On the front panel are controls for gain, phase, low-pass frequency, and a single band PEQ. On the rear are additional controls for high-pass filter, auto power-on/off, and bass boost. Overall it is a very flexible unit with lots of features. It did not seem to have any difficulty driving the pair of SBE-118s even at high levels for extended periods of time. The controls are well-labeled and easy to use. With the AVR crossover set to 80Hz, I set the low-pass frequency on the amp slightly higher (based on measured response and trial/error), set the PEQ to boost 6dB at 18Hz with a wide bandwidth (based on Chane recommendation and listening tests), phase at 0º, and adjusted gain based on preference/measurements. Again, the flexibility of the Dayton amp made setup very easy.
General Impressions
My response to the thought of stage monitor/PA system sound quality tends to be something like "yuck", and yours may be too. Let me be clear that Chane's Theater Tens sound NOTHING like that. They sound natural, balanced, clean, and lifelike. My ears tend to be a bit sensitive to higher frequencies making brighter sounding speakers sound a bit harsh. The Theater Ten sounds very smooth to me and they have been very enjoyable to listen to. They were not harsh sounding at any point during my review. Movie dialog is presented with excellent clarity, and music is very detailed and dynamic. The large woofer, though it requires the aid of a sub for deep bass, is balanced and smooth up through the the midrange and the crossover to the compression driver is seamless. Imaging is accurate and stable, with good separation between elements. Although I did not move them around much due to my limited placement options, they did not appear to be overly sensitive to positioning and/or toe angle. The sweetspot was wide enough to create a nice soundstage for all of the seating positions in my home theater. I really can't complain about the sound quality of this speaker, especially considering the modest asking price.
I would not call myself a basshead, but I do like good clean, deep bass reproduction when the content requires it. The SBE-118 is more than capable of that, without overdoing it. It has the muscle to pound out intense action movie sequences with authority, but enough finesse to provide a rich music experience. It blends well with multiple types of speakers and is not intrusive during the more quiet moments. The pair, properly positioned, easily knocked out the pesky room modes that tend to cause some unfortunate dips in response below 70Hz. They performed their job, and did it with authority. I know, it sounds like rainbows and butterflies, and it is important to mention that I spent quite a bit of time setting these up and trying different crossover, phase, and PEQ settings. Dual subs can be tricky, and they're all sensitive to room placement. Once I had them set up though, these SBE-118s definitely made it worth the effort.
Music Performance
Dave Matthews & Tim Reynolds (Live At Radio City, Blu-ray)
[Taken from my review for the Onkyo TX-NR737]
I tried stereo and surround modes with this Blu-ray and both sounded excellent. Start it up, turn the lights down a bit and it's easy to just relax and listen all the way through this concert. I got the feeling of being inside the Radio City Music Hall, surrounded by hundreds of other fans. Much less smokey than a typical Dave concert, but I wasn't missing that part of the experience. The vocals and acoustic guitars complimented each other very well. Even though there were only two instruments on stage, a rich sound filled the room. Clarity was excellent and nothing seemed out of balance.
Movie Performance
Transcendence (Blu-Ray)
Although a great action movie is always a good choice for a speaker test, I also like to include movies that focus on dialog and other "normal-life" stuff. All vocals were completely lifelike and made it feel like the characters were right there in the room with me. Without giving too much away, I will say that throughout most of the movie, the main characters are communicating with a couple different forms of artificial intelligence which have been given their own voices. In the mega-complex that houses one of them, the AI's voice seems to come from all directions at times, but with an almost tangible presence in the room. The transition from the omnipresent words of the AI and the focused dialog of the main characters was very distinct, adding to the mystery of the relationship between the two. Beyond the dialog, the soundtrack includes a lot of very subtle sound effects and textures to augment the sci-fi imagery on the screen. The Theater Tens presented these environmental details with excellent clarity, but kept them balanced so they did not interfere with the dialog or action.
Oblivion (Blu-Ray)
I would be lying if I said I was not interested in hearing what kind of deep, thunderous bass these SBE-118s were capable of producing. The Oblivion soundtrack gave them plenty of opportunities to prove it. Each time Tech 49's maintenance ship took off or landed, the Chane subs shook the seats and floor, as though a rocket powered space craft were really close enough to be rattling my foundation. And that's with plenty of headroom yet. The movie is full of big, deep bass. Not just booming bass, but bass you can feel. The 18" duo handled it all with ease.
Open Range (DVD)
While it has a great plot, Open Range is maybe most well known for its dynamic recreation of a wild west gunfight. I'm not going to say I skipped right to the end... ok, yes I am. I skipped right to the end for the final action sequence. Charley's first revolver blast just rips through the room. You can feel it as much as you can hear it. It was startlingly realistic. As expected, things escalate quickly. Pistol, rifle, and shotgun fire come from all directions with incredible intensity. What makes it even better is the presence of the echo of the shots, bouncing off the mountains, the chunks of wood and shards of glass being scattered about, boots shuffling through the dust. No detail is lost. The Theater Ten and the SBE-118 really shine here, and the whole system instantly proves its worth and value during a scene like this. A friend happened to be at the house and sat down to watch part of this scene with me. All I could hear from the back row repeatedly was "oh my goodness...oh my GOODNESS this is awesome!". Oh your goodness indeed, it was awesome.
Overall Value
The word "value" is often used as a sort of disclaimer for cheap construction or compromised performance when it comes to home audio electronics. Although I consider the Chane speakers and subs to be a great value, their design and performance are far from cheap or compromised. They have taken advantage of simple aesthetics and internet-direct sales to reduce the cost of these models, and passed that savings on to their customers. They have certainly not skimped on performance though, and I would call this system an excellent deal. Sure, $2400 for the whole package might seem like a lot, but $300 a piece for the Theater Ten? That's what I call a bargain. Advanced DIY-ers might say "I could build my own sealed passive 18" sub for less than $500" and it's possible. Not much of a deal though, in my opinion, when you add labor and other factors to the DIY cost, and the years of R&D that Craig Chase has poured into these monsters.
Conclusions and Recommendations
It is no mystery that Chane has well-informed, budget-conscious home theater enthusiasts like us in mind when developing speakers and subwoofers. They know what matters to us, and that's performance. The Theater Ten offers excellent dynamics, imaging, and clarity, and blends well with conventional home audio speakers in a surround system. The SBE-118 has power and finesse, and is built like a tank. Both offer big sound in a relatively small package at a very competitive price. Considering the price and performance, I can confidently recommend both the Theater Ten and SBE-118. Did I mention Chane Music & Cinema has partnered with Home Theater Shack to GIVE THIS WHOLE SYSTEM AWAY to a lucky member of our forum? Yeah, I'm just a tad jealous BD55.
Review Discussion Thread
More About This Chane 3.2 System
Specifications
Product Site
Chane Theater Ten
Chane Subwoofer Power Package Two
MSRP
Theater Ten: $300 (each)
Subwoofer Power Package Two: $1500 (system)
Overview
The affordable horn-assisted theater monitor
What do we all want from a real, pro-grade, home theater and multichannel main monitor speaker? Clean, clear, and dynamic sound. Big sound.
The prosound world has known about the efficiency and fidelity - and the audible purity and focus - of the two-way, horn-assisted, high-energy studio loudspeaker for decades. A good horn is an indespensible asset to raising the entire speaker's dynamic range.
How do we make a proper theater monitor?
The compact new - and highly affordable - Chane Theater Ten Monitor is Chane's version of a pro monitor in an ultra-value product. Its 20" x 12" x 11" format houses a design that's the simplest, most acoustically pure way to employ a horn.
The Theater Ten replaces common speakers to deliver a far higher caliber of clean, clear music and cinema in even the largest of theaters. The Theater Ten really is an alternative to compressed soundtracks, unintelligible dialog, and out of focus music common in consumer audio.
The Theater Ten's high system sensitivity and high power handling achieve effortless, macro-dynamic reproduction of the loudest movie effects and the most powerful orchestra crescendos.
At the opposite end of the spectrum the Theater Ten captures the minutest sound cues that are just as essential to realism. The Theater 10, with its low inductance, linear 10 inch woofer, a bi-radial loaded compression driver tweeter, and a pro-grade crossover network to seamlessly integrate them, vividly brings everything to life.
Under a large screen the Chane Theater Ten angles for best dispersion. The horn is easily rotated ninety degrees to convert the Theater Ten to an excellent center dialog speaker.
A real pro monitor. We used the good stuff
The Theater Ten is a real prosound speaker. It's cabinet is a real prosound enclosure, and the internal electronics, hardware, and fixtures are too. We use a recipe perfected by years of exposure to situations, conditions, and demands no consumer speaker ever has to face.
More features for less
The Theater 10 will fit in even modest size rooms - add a Chane subwoofer and the five behemoths it used to take to recreate that sense of being there are gone. The Theater 10 crosses over to a subwoofer at 80 Hz. and operates to nearly 20kHz., plus/minus 3 dB.
The challenge had been exceptional value
Not anymore. Smart design and economy of scale bring the quality and great sound of high-end prosound to earth for your theater. The Chane Theater Ten is a genuinely affordable alternative to Big Box, Big Brand low-output loudspeakers, and its value makes it a fraction of the cost of elaborate, custom designs from the speciality market.
Inside the Theater Ten is a heavy-duty, high-output 10 inch mid woofer with a wealth of performance features. It covers the 4.5 octaves from 80 to 2000 Hz. with exceptional linearity, which means crystal clear dialogue and music that sounds like an instrument, not a loudspeaker.
Above 2000 Hz, a high quality compression driver combines with a 60 x 90 degree horn to create treble that is always transparent, never harsh. A large, low-velocity vented port tunes the Theater Ten's bass output.
Get a big bump in sound for the cost of an average consumer brand
The Chane Theater Ten is the most value-packed pro-style super monitor around. At its low cost, and with the ability to be used with a variety of home theater receivers, the Theater Ten monitor brings the dream of a live performance to a previously unattainable price point. Two or three can revolutionize your media experience.
Features
Theater Ten
  • 1" compression driver high frequency element
  • 60 x 90 degree horn
  • 10" midbass driver with alloy frame
  • Precision dividing network
  • Heavy, solid MDF cabinet
  • Pebbled black PVC finish
  • Includes black steel grille
  • Priced, packed, and shipped individually
  • Manufacturer's warranty included
  • Includes Chane Music & Cinema's 30 day in-home satisfaction guarantee
Specifications
The Chane Power Package Two is a complete, self-amplified bass system, including subwoofers, amplifier, and internal equalization. Raw bass and amplifier products are available elsewhere on this site.
Cabinets
  • One inch (1") MDF* construction
  • Two inch (2") driver baffle
  • Mitre edge joints for maximum strength
  • 4 coat catalyzed black semi-gloss finish
  • Aluminum input plate with heavy plated multi-way input terminals
  • Stainless hardware
Drivers
  • 18" proprietary heavy duty woofer
  • Treated black paper cone
  • Half-roll edge suspension
  • Cast aluminum frame
  • Double-stack ceramic ferrite magnet
  • Vented motor pole
  • Flat rear suspension
Dayton SA-1000 Amplifier
  • Heavy-duty steel chassis with brushed aluminum faceplate, rack-mountable or tabletop use
  • Patented, efficient, tracking down-converter power supply
  • Single channel, high current Class AB output stage
  • Low frequency parametric EQ
  • Soft clip circuitry
  • Manual, auto, or triggered on/off modes
  • Switchable subsonic and bass boost filters
  • High level passthrough output on RCA connection
  • Double set of heavy five-way speaker binding posts
  • Detachable IEC line cord
Equalization
  • User adjustable between 23 and 100 Hz., +/- 3 dB
*ECC 4-11, Ansi A208.2-2009, California 93120 Phase 2 compliant.
System
  • Frequency response, raw:
  • Frequency response, equalized as designed:
  • Output 20-31.5 Hz: 113 dB*
  • Output 40-63 Hz: 122 dB*
  • Output 20-63 Hz: 119.2 dB*
Cabinet
  • Dimensions: 22 x 20 x 20 in
  • Dimensions: 560 x 508 x 508 mm
  • Weight:
  • Vents: None - equalized acoustic suspension
Driver
  • Nominal diameter: 18" / 450 mm
  • Voice coil diameter: 3"
  • Power: 1kW peak input
  • Impedance: 8 Ohms nominal, X Ohms DCR
Amplifier
  • Power (0.92% THD): 497 W, into 8 ohms. 950 W, 4 ohms*
  • S/N ratio: 98 dB A-weighted
  • Power supply efficiency: 86%
  • Input impedance: 12K ohms
  • Subsonic filter: -3 dB @ 18 Hz, Q=0.8
  • Bass boost: +3 dB @ 25 Hz, Q=1.4
  • High pass output: -3 dB @ 80 Hz, 12 dB/octave
  • Low pass adjustment: 30-200 Hz
  • Phase adjustment: 0°–180°
  • Parametric EQ frequency: 18–80 Hz
  • Bandwidth Q: 0.1–1.0
  • Level: -14.5 dB to +6 dB
  • Dimensions: 17-1/2" W x 4" H x 13" D (tabletop configuration)
  • Power requirements: 120/230 VAC, 50/60 Hz
  • Stand-by power rating: 120V 24W; 230V 18.4W
  • Weight: 20 lbs.
*Power rating based on one-third power duty cycle.
User Adjustable Equalization
  • Freq: 25 Hz
  • Level: +3 dB
*CEA-2010 specification. Measured at 2 meters, continuous RMS. Add 9 dB for 1 meter peak input.
More About This Review
Features
Reviewer
Peter Loeser (Archive)
Peter’s Home Theater
The evaluation of this equipment was conducted in a 14"3" x 16'10" (2300ft³) sealed home theater with seating for seven. First reflection points on the side walls have been treated with GIK Acoustics 244 panels. Speaker locations are fixed within the parameters of the THX/Dolby/DTS/Audyssey recommendations for up to 11.1 channel surround sound. Subwoofer placement is determined by ear and REW measurements for best response before any EQ or room correction is applied. All measurements are taken with Room EQ Wizard and a MiniDSP UMIK-1 (calibrated by MiniDSP). In most cases, the majority of the review is done from the main listening position, however subjective evaluation may also be done from multiple locations to test uniform system response throughout the seating area.
Audio Equipment
Receiver: Onkyo TX-NR737
Mains & Center: Chane Theater Ten
Surrounds: Definitive Technology Studiomonitor 350
Subwoofer: Chane Power Package Two
Video and Source Equipment
Display: LG PV250 60" Plasma TV
Blu-ray Player: OPPO BDP-103
Media Streaming: Apple TV
Media Server: Mac Mini Server
Cabling
HDMI: Monoprice/Rosewill with Redmere
Speaker: Monoprice 12ga CL2 in-wall
Sub/Interconnect: Monoprice CL2 RG6 Coax
Status
Not open for further replies.
1 - 1 of 1 Posts
1 - 1 of 1 Posts
Status
