I wish... Paradigm Servo 15 Version 1.
The end plan are 2 F12 or F12G's as long as the Canadian dollar gets better.
I wish... Paradigm Servo 15 Version 1.When you say 'servo' sub, are you referring to a Rythmik by chance?
There's certainly nothing wrong with that subwoofer.I wish... Paradigm Servo 15 Version 1.
Given what you have now, I'd suggest the E/F15HP instead. It would better match the capabilities of the Paradigm.The end plan are 2 F12 or F12G's as long as the Canadian dollar gets better.
Thanks for the kind words, Lou. Sorry, I do not know much about wall mounts, and would not want to be responsible for a 27 lb. brick falling on someones head! :whistling:Your impressive review is much appreciated! The Chane A2rx-c doesn't seem to have any wall-mount provision. Approaching 30+ pounds, I understand why unicorn mounts need not apply. Can you please share, or can you recommend a wall mount for surround purposes? Maybe something similar to Willis7469's clamp-type mounts (discontinued)? TIA!![]()
Great read Dennis! Looks like the A2rx are for real!
This was a great read. Made this Columbian Coffee much more enjoyable.
Thanks, guys!Excellent review, Dennis. Thank you for bringing the A2 system to life for us.
Thank you, Jon. It was my pleasure to review such a fine loudspeaker.I just emailed Dennis thanking him for his effort and commending him on a particularly clear and pleasant review. It's one thing to find favorable remarks about your product in the press, but it's another to see such a nicely written and presented piece. Thanks again, Dennis. This is genuinely good reporting.
Thank you, Bryan!Great review, Dennis! I enjoyed reading it very much, and I'm glad to hear that the Chanes are living up to their reputation, especially the reputation they have on this forum.
It's interesting to note how at times, with some recordings, you thought perhaps the tweeter was held back just a smidge, but later on other recordings decided maybe it was right where it should be. Did you feel the slight lack of resolution was the result of a tweeter intentionally brought down in level as part of the design, or was the tweeter itself not quite capable of the last bit of resolution regardless of its level relative to the rest of the system?
I'll do my best to relate what I've read and how I understand it. Disclaimer: Accuracy is not guaranteed.My heart wants the A5rx-c but I heard the A3rx-c for some reason are the best for 2 channel music..
I've listened to several new speakers breaking in and agree with you that usually it only takes a few hours, some don't need any break in (or at least I couldn't hear any change)....Once a speaker's mechanicals are exercised a little bit (<1 hour) it should be good to go.
There is no way I would have invested 30+ hours into "break-in", that is just ridiculous.
There is always the proposal that it's not the speaker changing its sound it's the listener's ears becoming accustomed to the speakers....
Glenn, your assessment is a perfect description of the way I understand it, too.I'll do my best to relate what I've read and how I understand it. Disclaimer: Accuracy is not guaranteed...
You bet, thank you, Charlie.Thanks for the review.
And special thanks for detailing the whole experience.
It is hard for me to say how long break in will take, until I feel it is actually completed. The planar tweeter does not have a lot of excursion, perhaps like many low excursion drivers, it takes a bit of time to loosen up?Not being much of a believer in extended break-in periods I must say you have the patience of a saint too.
In the end I am glad you had an enjoyable experience
It's not easy to communicate this every time, but while SplitGap (XBL2) may sound like just another trademark, when you can virtually double the midwoofers' linear excursion and cut distortion about in half, it can be audible.I ran the whole movie at -2 dB, and we were both amazed how loud, while maintaining that smoothness, the planar could get. As I stated in the review, the dual woofers never seem to come anywhere near their limits, either.
The decision to move lots of air certainly does give the A2rx-c a marked advantage. The -2 dB setting for that particular movie is arbitrary, and as with most TV viewing I do, level is set to bring the volume level of spoken word up to a realistic level, around 70 dB or so. Whatever happens after that, explosions, gunfire, whispers, background sounds, should be rendered correctly as well, if the studio did their job right.It's not easy to communicate this every time, but while SplitGap (XBL2) may sound like just another trademark, when you can virtually double the midwoofers' linear excursion and cut distortion about in half, it can be audible.
The tweeter is comparable: Roughly four times the surface area of a conventional dome grants a proportional reduction in distortion.
While the overall design is ultimately responsible for the presentation in the room, hopefully it's been given something important to work with.
If you are crossing a speaker over above the port's tuning, boundary reinforcement at lower frequencies will be greatly reduced, be it the center or the others.I would like to know how does the A2rx-c with a port plug sound and perform vs open ported. And could anyone post any measurements of ported vs plugged?
The reason is my HT setup I have my TV mounted on the wall and the center is under it on the fireplace mantel. So the center speaker has to be up against the wall with just enough room for the wires.
And if I plugged the center, would I have to plug all the others if I did a 5.2? (Running Dual 18 inch subs).
Red, the difference between the two modes is that the bass reflex, open-port mode makes each of our four models relatively full-band speakers (lacking the bottom octave plus a little). The rolloff is the typical ~4th order function, meaning -24dB/octave. Deep(est) bass; fast roll-out.I would like to know how does the A2rx-c with a port plug sound and perform vs open ported.
