1 - 15 of 15 Posts
I have a cheap Yamaha receiver hooked up to two monitor 60 Polk tower speakers and one cs2 center from Polk. I have two cheap Yamaha surrounds hooked up as surround speakers but they usually are not used. So I have a 3.0 system right now. Whenever I play music above -9.5 volume on the reciever it will shut down. When I turn it back on it says "check sp wires" and will run as normal until I turn it up too loud again. What is causing this? I just checked all my wires and they look fine, and there should be no reason for my reciever to crash only playing three speakers.. Any ideas?
Plain ole user
You may just be reaching the limit of the ability of the amp, or it could be defective. What model and how old?
Discussion Starter #4
The model is htr-3063 and it's about two and a half yeas old. I've check and re checked wires, both on speakers and going into the receiver.. I have my towers bi-wired, could this be causing the issue?
Plain ole user
How long have you had this configuration and when you say bi-wired, what exactly does that mean?
Discussion Starter #6
Well I've had the speakers and receiver about the same amount of time but I've had this configuration for about a month and have had no problems until recently. That's what bugs me.. And all I mean is I have two wires running from the speakers to one single terminal on the receiver.
Plain ole user
Are you sure there are no strands touching the other polarity or the chassis?
Discussion Starter #8
Just took everything out and re wired it all. Not cutting off even at max volume. But..... For some reason the tweeter my left front speaker is no longer playing?????? I literally just listened to it before I re wired.. Never ends does it
Discussion Starter #11
Do you think the shorting of my receiver is causing all my tweeters to go out? This is beginning to become very frustrating.
Plain ole user
You may have had a failing tweeter that was shorting across windings causing the shutdown. It probably finally opened up.
Discussion Starter #13
Well now I'm out 2 tweeters.. I have had Polk already send me two since one was damaged during shipping. Wonder what they are going to say when I want 2 more hahaha..
When you said max volume, was the amp distorting? If so, it could have been in clipping, which sends nasty harmonics to your speakers that can damage and even fry tweeters.
By chance, do your speakers have fuses? Not sure any modern designs do, but fuses were used years ago to protect tweeters from being overdriven and blown.
Discussion Starter #15
I have my volume trimmed to where it won't go where it distorts and sounds nasty.. Just relativity loud. Around -5 on the receiver. And no the polks do not have fuses. I'm listening to music now and the lack of tweets is extremely noticable... Ugh
1 - 15 of 15 Posts
