61 - 77 of 77 Posts
ChromaPure 2.5.6.42258 is now available for download.
Release Notes
The only change is a fix for the grayscale problems with the "Reset calibration settings to the default" reset mode in Lumagen auto-calibration.
ChromaPure 2.5.7.29716 is now available for download.
Improvements
We changed the "Reset to Factory Default" option in Lumagen auto-cal to work in the YCbCr mode.
Bug Fixes
We fixed a problem with the "Reset calibration settings to default" in Lumagen auto-cal that would result in inaccurate pre-calibration values.
ChromaPure 2.5.8.24553 is now available for download.
New Features
Added support for the Colorimetry Research CR-250 spectroradiometer
Added support for the Spyder 5 colorimeter
Added support for the Display 3 II colorimeter*
Added a control panel in the Options module for the Display 3 colorimeter that provides the user with extensive control over the performance of the meter.
Added luminance to the Meter Correction module.
Bug Fixes
Fixed a problem with the DVDO TPG signal generator outputting PC values in some modules.
* The Display 3 II is a Rev B of the X-Rite i1D3 colorimeter. This meter includes new hardware/firmware features that support refresh rate synchronization (must use the AIO read mode). This requires the user to point the meter at a 100% test pattern during initialization.
Tom Huffman has announced that the ChromaPure 3.0 release date is only a matter of weeks, not months.
All of the core components are finished, they are working with the small bug fixes, clean-up, and documentation.
Discussion Starter #65
Excellent! Can't wait to give it whirl on my new bulb for my Epson 3010. :T
Hi CP users, Tom Huffman has announced today that ChromaPure 3 will be released finally in the next few days.
In advance of the official release, Tom uploaded a demo which provides some indications about the new look and feature set of the new version release.
http://www.chromapure.com/movies3/userInterface.html
ChromaPure 3.1.1 is now available for download. It is free for license v3 users.
Bug Fixes
The code that accommodates international regional formats was not included in the initial 3.1, which led to unexpected behavior on non-English language PCs.
Attempting to switch between the default tablet UI and vertical or horizontal versions of the traditional UI caused the application to shut down.
There was no intensity selector when the Calibration Disc mode was selected.
The Color Management module suffered from various types of instability and unexpected behavior.
ChromaPure 3.1.2 is now available for download. It is free for license v3 users.
Enhancements
We have added support for HDR color calibration. Please use 50% intensity and 50% saturation settings to calibrate HDR sources in the Color Management module.
Bug Fixes
The Murideo test pattern generator did not behave normally and could cause the application to close unexpectedly.
The Lumagen and AccuPel auto-connect feature did not work for a small minority of users. We could never reproduce the problem here, so could not provide a fix. Instead, we have disabled auto-connect. Starting with this release, when setting up either of these devices you will have to manually select the correct Com port.
Running the report for Lumagen Advanced Auto-calibrate would sometimes cause the application to close unexpectedly. Even when it did run, the dE values for post-calibration color gamut were incorrect.
After initializing the meter, users would find that when subsequently navigating back to the Initial Setup page the meter's mode would be apparently set to CRT.
ChromaPure 3.1.2 has been re-released to fix a problem with the luminance measurements of color in HDR10 mode.
ChromaPure 3.1.3 is now available for download. It is free for license v3 users.
Enhancements
We have simplified the X-Rite i1D3 initialization procedure. We have eliminated auto-detect and provided the user with the ability to select 25Hz, 50Hz, or 60Hz as the sync value.
We added degamma to HDR10 which allows ChromaPure to support HDR10 using external signal generators.
Bug Fixes
Here is a list of issues that have been fixed.
There was a cluster of problems regarding importing calx session files.
3.0.8 calx files did not import correctly. The gamut data in the CIE chart is still broken. This will be fixed in the next release. All other issues were resolved.
When double-clicking calx files the application would open, but no data would appear.
Imported calx files did not show average summary data.
Imported calx files that contained auto-cal data prevented the user from accessing the data logs and full color information.
When clicking Measure All without having a meter initialized the system would generate a lengthy loop of error messages.
There was a refresh problem that occurred when changing Color Intensity. The values did not update in Color Management until the user restarted the application.
There was a refresh problem that occurred when changing the Reference Gamut. The saturations for the gamut did not update. NOTE: When changing the Reference Gamut you will lose all of the data from the previous gamut. If you want to keep this, save the data first or run a report.
Load and Save were missing from the classic UI.
The Signal Generator drop-down would not allow the user to access all of the test patterns.
ChromaPure 3.1.4 Beta is now available for download. It is free for license v3 users.
Bug Fixes
This 3.1.4 beta fixes some problems getting stable readings at low light levels with the i1d3 and with the proper display of the signal generator test pattern drop-down.
ChromaPure 3.1.4 is now available for download. It is free for license v3 users.
New Features
The White Balance module now includes gamma information.
Users can now select a Slow mode for the i1D3. Use this feature only when measuring black level, such as when measuring contrast. This is necessary because the default AIO measurement mode will not read below 0.01 nits.
We have added support for the Quantum Data 780E signal generator.
We have added a new gamma reference, HDR10 – Projector. Use this gamma target when calibrating front projectors using HDR10.
The options module now includes a selection for Gamut Overlay. Select this option to see another color gamut superimposed on the reference gamut. This is useful when calibrating Rec. 2020. It allows you to see how the measured colors fit into other gamuts.
Enhancements
The Built-in signal generator has been adjusted to facilitate easier use. Users no longer need to rely on a madVR utility to get proper levels.
Bug Fixes
We have fixed data import problems with ChromaPure 3.0.8 data.
We have fixed an issue that affected the user’s ability to scroll through the drop down list of individual test patterns for external signal generators.
We have updated the Excel report to conform to the data structures of 3.1.x.
NOTE: DVDO Duo Auto-calibration will be relesaed soon as part of 3.1.5.
ChromaPure 3.1.5 Beta is now available for download. It is free for license v3 users.
Bug Fixes
The Brightness and Contrast Built-in test patterns have been modified to match the proper levels.
Initialization problems with the JETI 1501/11 have been fixed.
The target gamma line for HDR - Projector in the Gamma and Grayscale modules has been fixed.
The Slow Mode has been activated for Display 3 PRO meters.
ChromaPure 3.1.5 is now available for download. It is free for license v3 users.
New Features
Auto-cal for the DVDO Duo has been enabled.
ChromaPure now supports the Lumagen Pro and HDR/Rec. 2020 test patterns.
We added support for the AccuPel 6000 signal generator.
We added a HDR10 – Projector selection to the list of available gammas. This provides the same curve as regular HDR10, but at lower luminance levels expected from projectors.
Enhancements
The ChromaPure application and calibration disc now list the colors in the saturation scale in the same order. Current owners of the disc can request a free update (download) or have a new disc mailed to them for a S&H fee of $3.00.
Context sensitive Help has been enabled.
21-point grayscale has been enabled for Lumagen auto-cal.
Bug Fixes
This release fixes three reporting errors.
RGB grayscale charts in the Custom report now reflects 21 point grayscale when selected in the calibration session.
Reports now correctly plot the HDR gamma target line.
Three of the charts in the Custom calibration report no longer cut off data.
Known Issues
The Lumagen Manual Control Tool does not currently sync with the selected grayscale mode. To fix this just clikc the Reset button on the tool prior to making grayscale adjustments. The tool is automatically synced when using auto-cal.
When selecting HDR10 for the Lumagen Pro do so after setting up the generator, but before displaying the first test pattern. HDR10 is activated only AFTER generating a test pattern.
ChromaPure 3.1.6 Beta is now available for download. It is free for license v3 users.
Bug Fixes
This beta release fixes some errors with the signal generator toolbar that affect both the standard Lumagen Radiance and the Radiance Pro.
ChromaPure 3.1.6 Beta 2 is now available for download. It is free for license v3 users.
Bug Fixes
We had been getting intermittent reports of instability with auto-cal. As part of the 3.1.6 release, we have improved ChromaPure's error handling, and as a result of this we were able to track down the problem. This release fixes it.
ChromaPure 3.1.7 is now available for download. It is free for license v3 users.
Bug Fixes
The application would drop data from the Color Management module when importing a previously saved .calx file.
The application would drop data from the Gamma module that included multiple gamma runs when importing a previously saved .calx file.
When selecting fL as the default luminance measurement unit, the Raw Data module would continue to show cd/m2 in some areas.
The Excel report was broken.
The application was not applying Pro corrections to the CR-100 colorimeter, and attempting to initialize the meter whose license contained Pro corrections would result in a fatal exception.
Deleting all of the data from the Raw Data module would result in a fatal exception.
Data in the Measured Color and Reference Color panels was difficult to read. We changed the color scheme to improve readability.
61 - 77 of 77 Posts
