Doesn't look ******* to me... I expected to see extensive use of duct tape. Looks like a nice budget setup to me.
You might want to hide your wires a little better so no one trips though.
On my first HT setup... I went to a fabric store and bought some black material and made the entire wall behind the screen black, and came out the side about 4' of black.Not *******, Ratchet, or Ghetto at all. Much better
than my temporary apartment theater, which consisted
of a DVD player, connected to a computer monitor, 2 cheap
Altec Lansing speakers, stacked on top of some UHaul
boxes!
If possible, I would paint the walls and ceiling to reduce
reflected light hitting the screen. In addition, possibly adding
some matte black framing around the screen area for additional
contrast.
I will probably go with some sort of framing, I'm just afraid right now that if I put something that is level on the the wall I'll see how far off level my projector is. As for reflected light, that and the acoustics are the reasoning behind the curtains. I don't know how much further I'll go, due to reselling in a few years. Worst part so far has been that I have to turn the sub down and put it on Styrofoam, to isolate it from the concrete floor because apparently I'm vibrating the neighbors (the joys of attached housing)Not *******, Ratchet, or Ghetto at all. Much better
boxes!
contrast.
When I did my walls black I lived in a apartment... You can just get the fabric and some fir stripping. Paint the fir stripping black, temporarily tape the material to the wall and then put the fir stripping up next to the ceiling. Then you use a few thin nails to hold it all in place. You can then stretch it to the fabric to the floor trim and tack it to the wall.I will probably go with some sort of framing, I'm just afraid right now that if I put something that is level on the the wall I'll see how far off level my projector is. As for reflected light, that and the acoustics are the reasoning behind the curtains. I don't know how much further I'll go, due to reselling in a few years. Worst part so far has been that I have to turn the sub down and put it on Styrofoam, to isolate it from the concrete floor because apparently I'm vibrating the neighbors (the joys of attached housing)
