1 - 3 of 3 Posts
I just got back form my local electronic component store and picked up some new caps for my cleanbox. I bought two types because I forgot which ones are better. The first is a 63V 1uF Metal Polyester Box Capacitor that was 3 bucks for 2. The second is a 50V 1uF Ceramic Cap that was 5 bucks for 2. Which is the better choice here?
Discussion Starter · #2 · (Edited)
Well I decided to use the 63V 1uF Metal Polyester Box Capacitors. Here is how it looks now:
This is the in room response before:
And this is after the mod:
Haven't listened to anything normal yet but it doesn't look much different. I think I had the levels set at 75dB before and 80dB this time though.
Well after only a few minutes of music I can definately hear more bass and I am liking it a alot :)
1 - 3 of 3 Posts
