1 - 8 of 8 Posts
I have a BenQ HT1075 and have a couple questions about routine
cleaning of the lens:
1) Is it permissable to use eyeglass lens cleaning solution on the
projector lens?
2) Is it Ok to use a cotton tip swab to apply lens cleaning solution
and then to clean the projector lens?
Thank you for in advance for any replies :)
I have heard of people using camera lens cleaning cloths.
I have been using eyeglass cleaning liquid in a spray bottle for years without any problems..
I just spray a little onto a lens cleaning cloth, clean the lens and wipe it dry..
Thank you for all the replies.
I am trying to be prudent and not cause damage
that I could not afford to repair right now. So far
I have only used the Shop-Vac, held about 3/4"
away from the lens to vacuum off the dust.
I am not sure if the lens itself is glass or a specialty
plastic product?
1 - 8 of 8 Posts
