1 - 1 of 1 Posts
Hi all,
I'm moving into a smaller home where i'll have only a single lounge room for my current home theatre / audio setup that was originally in two separate rooms.
I had in the study a Yamaha HTR-2067 amp (5 speakers and a sub), a Behringer Microphono PP400 Phono Preamp, and a Pro-Ject RPM 3.1 Genie turntable in the study to listen to records.
In the living room I had a Hisense smart TV, and a Samsung HT-H6550WM Home Theatre System.
In the new house i'll only have a single room for all this kit. What would be the best way / is there any way to integrate these current systems to work in sync with each other? i.e. use the Yamaha to take the Samsung dvd and Pro-Ject turntable input and send it to my speakers and subs? What I am after if possible would be to utilise the kit I currently have to get the best sound from my turntable and DVD player/TV, whilst trying to use as much of the current kit as possible.
Or would I be best to keep them separate as I had previously?
Information on the system components below.
Thank you for your advice and time!
Samsung HT-H6550WM: http://www.samsung.com/au/support/model/HT-H6550WM/XY/
Yamaha HTR-2067: https://au.yamaha.com/en/products/au...l#product-tabs
Pro-Ject RPM 3.1 Genie: http://www.project-audio.com/main.ph...=rpm13&lang=en
Behringer Microphono PP400 Phono Preamp: https://www.storedj.com.au/behringer...0-phono-preamp
1 - 1 of 1 Posts
