Re: Coming soon. FW18.1
Carlos and I havn't realy discussed the mods yet so its still very up in the air.
Here is some max output #'s
[email protected];
105.6db @10Hz
114.4db @15Hz
125.5db @20Hz
118.7db @25Hz
117.7db @30Hz
123.7db @ 40 Hz (amp limited)
Sealed 130L net, never clipped the amp.
104.6db @10Hz
107.4db @15Hz
116.5db @20Hz
111.5db @25Hz
112.7db @30Hz
120.6db @ 40 Hz
(the numbers above 20hz seem a little lower than expected I may check things over and do them agian and see if I can't get more)
also for comparison the FW15.3 with EDLT1300 amp did;
102.6db @10Hz
108.4db @15Hz
118.8db @20Hz
112.0db @25Hz
113.8db @30Hz
116.0db @ 40 Hz
So far impressions around here are they both sound very good, the 15.3 is a little "softer" "smoother", the 18.1 is "harder" "louder"(even with the levels set the same) But with a little Eq to bring up the bottom end of the Acoupower to match the 15.3 they seem even closer.
With low frequency sine waves the Acoupower seems to have a little air turbulence noise coming through, not at all noticable with real material though.
