1 - 13 of 13 Posts
Someone posted this statement on the Klipsch forums. Not sure I understand it entirely. Can anybody clarify?
"Room EQ Wizard will not address room anomalies as EQ is only effective in treating minimum phase direct sound - thus eliminating its use for room correction as the room introduces non-minimum phase reflected signals that are summed with the direct signal (a process called superposition) and which cannot be effectively EQ'd."
Why can't it be used to help with the room acoustics? I see using REQ with trial and error...take reading...add traps or absorption...take reading...move traps/absorption until curve is to your liking.
G
I don't see how the graphs with response measurements can lie, but I'm just a hillbilly, so who am I to say? :dontknow:
G
The statement is incorrect, principally in its assumption that only direct sound is minimum phase. This is a fundamental misunderstanding of minimum phase systems. Room modes (in particular those below a few hundred Hz) are minimum phase phenomena (substantially behaving as 2nd order biquads) and are effectively countered by 2nd order biquad correction filters such as those implemented in the BFD pro and many similar parametric equalisers. It is, however, unnecessary to engage in lengthy academic discourse on the topic since measurements clearly show the effectiveness of the approach.
G
What you do is copy this post and go back over there and lay it on the poster there. He's not gonna be able to argue rationally with you. He'll probably never know you don't undertand what it says. I don't undertand what it says either, but it sounds pretty intelligent and convincing to me... and trust John. :R
Sonnie,
I think he replied to my question about his statement about REQ:
mas wrote:
"So...what can you EQ?
We have inadvertently stumbled onto a large and important topic, but I will try to toss a few ideas out...but this topic does deserve a more thorough treatment and it will help to have a greater understanding of a few underlying topics... And hopefully we can address this issue in greater depth soon after we deal with a few other issues that we will be tossing out beginning this weekend... ;-) (Mysterious, aren't I? ;-)
First, may I suggest the link below. Superposition is a rather abstract concept to grasp...until the light goes on, and then it will seem rather obvious. And I can just imagine you saying : “Sure, that’s easy for him to say!” ;-)
It is often presented graphically with linear waveforms, which while useful, is somewhat hard to translate into the world of sound. For sound, it is often easier to refer to the format normally encountered when using a wave tank – spherical waveforms reminiscent of dropping a pebble into a puddle.
For a nice example of the interference patterns that this model presents – and which I think you will find very useful to understanding the effects on polar patterns, may I suggest this site:
http://id.mind.net/~zona/mstm/physics/waves/interference/twoSource/TwoSourceInterference1.html
May I suggest playing with the two sources down near the bottom edge of the 'tank', and switching between the small, medium and large setting to make the interferfence patterns more prominent. Note that the regions of 'dark bands' are nulls - regions where the polar response is absent for the particular frequency viewed. In other words, that frequency's acoustic energy has been cancelled and you would not hear it in those regions.
Now, jumping back into the EQ question – this is actually a pretty large topic, but I will try to summarize it here without going into too much depth or explanation. Also, note that this also makes reference to large room acouistics which do not apply to small room acoustical environments such as a home theater or home litening room - for small rooms (unlike large acoustical spaces) please understand that reverberent fields do NOT exist! More on this to come!
Allow me to cite an article from the winter 1989 Syn-Aud-Con newsletter:
“What can an Equalizer Equalize?
The question “What can an equalizer equalize?” needs to be asked. Some claim to equalize the room. Is this possible? We think not.
When an electronic or passive equalizer is installed in between a mixer and a power amplifier we need to know that all it can equalize is the electrical signal being sent to the loudspeaker.
What comes out of the loudspeaker?
What comes out of the loudspeaker is called direct sound level, Ld. Early reflections from the floor, walls, and ceiling are called the early reflected level, Lre, and late-in-time, homogenous mixing sound is called the reverberant sound level, Lr.{Please note, Lr is present only in a Large Acoustical Space – not your home theater or listening room.}
When an electronic equalizer is employed it not only alters the Ld at the listener position, but also the sound power level, Lw, of the loudspeaker. {Note: If interested, Sam Berkow has a number of articles referring to the need to reduce a subwoofer’s crossover point with increases in gain. PM me. ) This in turn affects Lre and Lr but has no effect on Ln {Lamb - Ambient noise floor – you may see it expressed symbolically as Ln or Lamb}. The question over the years has been “how much can I alter Ld without throwing the baby out with the wash?” Experience has shown that the answer is “not much”. Certainly not enough to drop a specular Lre having a full frequency response.
The Audience Effect
The so-called “audience effect” came about by people looking at the sound fields with 1/3-octave real time analyzers.
What an RTA sees is the total sound field level, Lt, which is the combined Ld, Lre, and Lr plus any ambient noise present, Ln (Lamb). { Unlike SPL meters and RTAs, time domain analyzers such as TEF are unique in that they display the component waveforms (reflections) and provide detailed information about the individual reflections instead of the simple summed result.}
{You might want to read those last two sentences again! ;-) }
Adjusting a sound system to a uniform Lt may or may not result in a sound you would want to listen to. In many cases the floor reflection can cause an operator to misadjust the direct sound level, Ld. Then when the audience arrives and covers the floor the misadjusted Ld is more clearly perceived and we say the audience affected the system.
Really? Think with me for a minute.
What can the audience do to affect Ld from a sound system? The answer, of course, is absolutely nothing. Therefore, it is clear that the audience can only alter Lre, Lr and Ln. Now, ask yourself the question “how can an equalizer adjust Lre, Lr and Ln {independently of Ld}? The answer is that it cannot.
I would hesitate to mention such obvious facts except for the remarkable number of articles appearing to claim the contrary. The only way an equalizer can cause a change in Lre, Lr and Ln is to do damage to Ld in the process.
What Can Affect Lre
Loudspeaker directivity factor, Q, is the classic way to handle unwanted Lre. Using a loudspeaker’s directivity to stay off of surfaces producing unwanted reflective energy is also one of the most cost effective solutions. The second approach is to use either absorption or diffusion.
Electronic Directivity Control
The increasing use of precision digital delays (i.e., 10 usec per step in contrast to normal digital delays of 1msec per step) to correct mis-synchronized loudspeaker arrays, where the mis-synchronization has resulted in directional lobing of the loudspeaker, demonstrates the importance and validity of directional control. {Additionally, limiting overlap of adjacent sound fields also minimizes the superpositional effects such as comb filtering upon sound fields as well.}
Good Engineering Practices
Today, thanks to advanced analysis in the hands of competent users, good engineering practice has become:
1. Adjust Ld by measuring it alone with a TEF analyzer.
2. Optimize the reduction of Lre, Lr, and Ln levels by means of controlled directivity and measured synchronization of arrays.
3. Fundamentally control Lre, Lr and Ln through traditional use of absorption, diffusion, and noise abatement techniques.
What does all of this mean?
The point I hope I have made is that electronic equalization in the frequency domain cannot correct phenomenon in the time domain outside of the minimum phase period (i.e., a few hundred microseconds). An EQ cannot correct for the summation of two or more out of phase signals. And thus they cannot solve acoustical room problems as so often claimed. Claims to do so should be rightfully regarded as mistaken.
An additional factor to consider:
Also, if I can mention one more issue without going into too much depth here or causing too much additional confusion (OK, I guess I am too late!;-) , comb filtering is the result of multiple sources reproducing the same pass band signal. As these sources are physically separated, the arrival times of the multiple signals are not coincident – this difference in time is referred to as a difference in “phase”. In audio parlance, “phase” is a fancy name for “time”.
Thus, what may have been a perfectly flat ‘DC to gamma ray’ frequency response with one transducer, now exhibits a notched response beginning at a frequency fundamental dependent upon the driver spacing that is the source of the phase (time) difference in the arriving direct signals. This notching is repeated at multiples of this fundamental frequency. And as this notch is actually a null created by the phase being 180 degrees out of phase, the signal is effectively cancelled at those points. And even with the best of equipment, it is difficult to increase the gain of a signal that has been cancelled and is no longer available to be processed!
Let me also mention one more corollary to comb filtering. As comb filtering is but one perspective of the sound in the frequency domain, this same phenomena can also be viewed from the physical realm in the form of the polar response. The polar response corresponds to a lobing of the dispersion of the acoustic energy into a physical space. Where the lobes are present, you hear the sound, where they are absent – in the notches/nulls, that energy is absent. What may have been a device featuring a perfectly hemispherical (cardioid) polar pattern corresponding to the perfectly flat frequency response, becomes a frequency dependent pattern of lobes, with the number of lobes being fewer and the Q (the ‘focus’ – think: spotlight = high Q, and broad floodlight = low Q) lower/broader for low frequencies, but increasing in number of lobes and in Q as the frequency increases. {If you have a chance, the next time you go to a concert, if you get there early and you have access to the entire floor, when they are playing a fairly ‘consistent’ musical selection (especially one with a solo vocalist or a piano), slowly walk from left to right across the floor, from one side of the auditorium to the other and listen. You may be surprised to discover that it seems as if someone is adjusting the EQ – the tone controls. As you walk from spot to spot, it will seem like various frequency bands of the music are either exaggerated or missing entirely. What you are experiencing is the entry and exit into and out of the lobes and nulls. EQ cannot fix this. Minimizing the overlap of multiple sources fixes this. But this is what many have tried to fix for years with an EQ. And what they have really done by adjusting the EQ, was to introduce a small amount of phase shift to the signal {*see below}, thus changing the phase relationship between the direct sound Ld and the reflected signals Lre, thus ever so slightly moving the polar lobing and the nulls – simply rearranging the furniture (the problem), but NOT fixing the fundamental cause of the problem.
I hope this has helped a bit! It can be a bit confusing at first, but I think you will find it clear after a bit of pondering and experimentation. And after you become aware of it, you will discover just how widespread an issue it is, and how destructive it can be. This (hopefully) will result in your returning to ask “OK, so what can I do about it?” And that is the subject for another discussion!
*“All 2nd-order bandpass or band-reject filters (active or passive) shift phase the same amount. (The bandwidth of this phase shift differs for various 2nd-order responses, but the phase shift is the same.). And when used to create boost/cut responses, do so with the same phase shift. Different phase responses do exist, but they are a function of boost/cut levels and individual filter bandwidths. That is, there will be less phase shift for 3 dB of boost/cut than 12 dB; and a 1-octave filter set will have a wider phase response than a 1/3-octave unit (but the number of degrees of phase shift will be the same). Figs. 1 and 2 demonstrate this. In Fig. 1, the phase responses for different levels of boost appear (cut responses are identical but mirror image). This verifies Pennington's rule-of-thumb regarding 10 degrees of phase shift per 3 dB of amplitude change.{T. Pennington, “Constant-Q,” Studio Sound, vol. 27, pp.82-85 (Oct. 1985}. Fig. 2 shows the bandwidth variation for this phase shift for wider and narrower bandpass responses.”
{Source: Operator Adjustable Equalizers: An Overview; Rane, Inc.}"
in one way i get what hes saying (mas), you cant equalise cancelations etc due to interacting waves, but i dont think any of us realy expect to, especialy with the sub, we cut gain, not boost.
he also mentions the audience problem, but to me the easy solution is eq when the audience is sat down :bigsmile: , after all our home theatre environments dont change much, we also have our faveourite seat (i eq only for where i sit, no one else would even notice), but you can take measurements from several places and soon see there are certain frequencies which are affected all over the room (200hz in my room for example, a 9db peak nearly all over the room, id love to eq that out)
he also meantions the phase issues with eq, i guess im more sensitive to spl over phase issues, as although ive not tried full range eq yet (other than built into a reciever autoeq thing) its very effective on the sub. i intend to experiment with full range either with convolver software or some behringer thing.
im afriad i agree with johns explination, you can argue the theory all you want, rew quickly shows the practicle (and positive) results.
edd
G
Whew! This is just something I don't even wanna try to grasp... I ain't smart enough for it. (Remember... hillbilly here! :R) Not that it may not be important for some folks... just not for me. I'm more of simple kind of guy with it comes to technical verbage. I use my BFD sub eq and it changes what I hear and I can measure that change. Whatever you wanna technically call, name or label what's happening is okay with me. :dontknow:
G
Ron, the mistake the author is making is not thinking about the frequencies involved - it may be that the original discussion was about full range responses? At low frequencies the wavelengths compared to the room dimensions are large enough that behaviour is minimum phase (a 50Hz tone has a wavelength of about 22 feet, primary reflections from the walls, floor and ceilings of the room arrive at the listening position with a phase shift of much less than a cycle). At modal frequencies in particular the low frequency behaviour is dominated by the room's modal response. The modal response of the room acts like a 2nd order biquad, the room is giving the same effect you would achieve if you fed the sub signal through a 2nd order eq filter whose gain matched the mode's gain at your listening position and whose bandwidth matches the mode's Q. By applying an EQ filter with the same Q and the opposite gain you counter the effect of the mode at the listening position. Outside the low frequency range the behaviour is no longer minimum phase and this doesn't work, which is what the author's post details, but that is not a range in which we are suggesting EQ should be applied.
G
I just picked up the thread and started to comment then I saw John's response at the end and it pretty much sums it up. This is a case of both sides of a debate being right, the debate and criticism being pointless if one just pays attention to the context.
It is absolutely true that dealing with the environment and using products that require less EQ in preferable for many reasons in absolute terms. The concept of using REW in the manner most of us do is, however, a sound alternative within the environment provided in home acoustics.
It is also important to realize that the parameters of large venues and live performace optimization are very different. Low frequencies in even a medium sized venue presents different chanllenges than in a typical home theater.
Dare I throw a few simplistic assumptions up to be shot down in flames? ;)
If we could cancel only reflective waves at the listening position we would have the equivalent of an anechoic room at low frequencies instead of a highly reflective one.
It would probably sound like being in a closely packed conifer plantation but even less interesting.
Fortunately we have a simpler situation in our humble HT/Stereo sytems.
It is assumed that the listener remains in one place. This avoids much unwanted complexity.
It is assumed that if we use equalisation it will be used to control only noticeable peaks and only at the fixed listening position.
REW will offer greater sensitivity to direct acoustic signals due to the very small delay (time=phase) between transducer excitation and detection.
Longer sinewave test tones read from our humble RS meters will average direct and reflected waves at the listening position.
We can arrange the subwoofer to be at a roughly equal distance from the speakers.
Given the very long wavelengths involved the phase errors of the direct wavefronts are diminished to almost zero.
Phase errors exist for all frequencies in all positions in a room except for direct wavefronts reaching the ear. The human ears can cope with out of phase audio waves from multiple reflections. Because we've beeen doing this since birth (in caves of various forms of sophistication) for several millions of years.
I am really not sure that the average human listener would prefer a perfect, fullrange, point-source transducer in a perfectly absorbing room. (or its electronically filtered, pasteurised and equalised equivalent)
If semi-anechoic conditions were so desirable we'd all be outside watching films and listening to music in our yards and gardens. Fortunately (for all of us) the great indoors offers rather more than mere shelter from the elements.
basicaly what i was trying to say chris, but much more elequent.
i still fancy trying full range eq, to begin with probabky armed with an mic and rew plus some convolver software and drc, i may try a deq2496 as well, audio is a very personal thing, you might like one thing, and hate another.
i always found with my pioneer avr and its auto eq on the main that at first it sounded very strange, but if you listened for an hour or 2 you got used to it, then when you switched off the eq it sounded terrible, a bloated boxy sound came out of nowhere, its amazing how our ears (or brains) adapt.
edd
Without wishing to get too far off topic:
I found boxiness was related to the roll-off point on my floorstanders.
Twiddling the knobs on an active crossover can be quite educational.
Colouration is something the ear seems to forget after a while.
Like Linn Kans which are more coloured than any speaker I've ever heard.
Yet I listened to mine for years and struggled hard to find anything to replace them.
1 - 13 of 13 Posts
