1 - 3 of 3 Posts
It will work, but I personally would not combine the two. The problem you will have is your Polk sub will reach its limits well before the eD sub will. Kinda the weakest link theory. I think you would do better with the eD sub alone.
I also posted in your other thread, Kenny, but I agree with Greg. If you were to get an eD A3-250 I think you will want to use only that as your subwoofer as opposed to mixing it with the PSW-111.
They will likely sound very different to you and mixing the two different sounds won't yield very good results.
1 - 3 of 3 Posts
