Yes. For both channels of the BFD’s outputs, the 1/4” and XLR jacks are paralleled (same thing for the inputs actually). So just get the cables of your choice to connect between the BFD and your amp – XLR or 1/4”.
Yes. For both channels of the BFD’s outputs, the 1/4” and XLR jacks are paralleled (same thing for the inputs actually). So just get the cables of your choice to connect between the BFD and your amp – XLR or 1/4”.My question is can I use the xlr output if I'm using the 1/4" input?
I suppose that there's always the possibility that your firmware update , didn't actually happen . Have you seen anything that would give a confirmation that it did ?Does anyone know if there is an easy step by step instruction of how to send filters from REW to a BFD1124? Please don't tell me to read the BFD manual...I've been pouring over it!
I know how to manually enter filters, but I recently upgraded the eprom on my BFD to 1.4 & would like to send files via MIDI. I've gone through the steps to allow the BFD to accept MIDI transfers, but each time I send over the file nothing happens.
Here are my specific issues:
1. How do I select a preset? Is it as simple as choosing PA in the filter mode & turning the dial to a filter number?
2. Does it matter which preset to overwrite went transferring filters from REW?
3. After the file is sent, I'm not prompted to save or do anything...nothing on the BFD changes. Am I missing a setting to allow the BFD to accept the file?
4. I assume the in/out button needs to be green, but it is not flashing during MIDI communication...does it need to be set any differently?
5. I'm using a MIDI SPORT UNO, which is recognized in the Comm setup of REW, connected via USB to the MIDI Input of the BFD. Seems simple enough, but is that correct? There are two midi output cables on the SPORT UNO & I've tried both. I'm using the "IN" on the BFD...not the Thru or Out.
Thanks!
