81 - 88 of 88 Posts
HTS Senior Moderator
Sounds like a good size screen..:T Is that an AT screen?
It would be preferable to move your projector back, if you have the room..and not zoom to fill the screen..
When you have it all set up, some pics. would be nice..
No, I'm going to try it non AT. I struggled with the choice. I prefer the firehawk material for it's versatility. It has it's cons, but IMO it's pros outweigh them for many installs, mine included. I could get it microperfed, but the main issue was the layout of the room. With my speakers and the required air gap to the screenback, I'd lose 2'. I have a corner door on a 17' wall and it gets to be a layout problem as I pull that screenwall back. And it puts the seating in a likely bass problem spot, and it eats into the other end of the room where I have other plans (room is about 30' long). So I just pulled the trigger and went non AT. I have B&W tower speakers and going AT would have dictated a speaker change too. The 804's are fairly slender and fit tight up to the viewing cone so I think I'll be OK. I'm 100% movies and TV so not too concerned about 2 channel performance. All that said, I stay busy with my HT related work so much I rarely have time to work on my own things. Like a dentist with bad teeth :D. I've been piddling with this theater rebuild for some time. I have the drywall stacked in there though so I'm getting closer. I got a new PJ at CEDIA which I'm happy with so far so that's been a little more of a driver to get'er'done. Maybe by spring. Maybe :)
That's a pity that you can't fit a screen wall in there..
I have a screen wall and I've finally bitten the bullet to put in an AVSeymour AT screen..
My screenwall is 2' out from the front wall and my monitor speakers have plenty of room not to be too close to the screen fabric..
I also only watch TV and movies, and all my movies are viewed at 2.35:1, regardless of their AR..The lens never moves..
What projector did you get?
Good luck with the re-build and let's see progress shots..
DOH! That reminds me I was supposed to call Chris today. Need to find out how close the recommend having the speakers from their 4K material. Happen to know?
Lens never moves for HD TV??? Too bad :) Obviously I'm in the move your lens camp ;)
I have Digital Projection Highlite Cine 260 HC. Wish they gave it a shorter name. :gulp:
From what I recall, it's about a min. of 3"..
I don't get that! :scratch: For HDTV the AR button on the projector remote is changed to 4:3 to give me a widescreen image with out moving the lens..
Not familiar with that projector..I'm presuming it's pretty pricey!
Chris said a difference can be measured at 20khz but not heard from 0-2". After that, no measurable difference.
Because you are throwing away your vertical resolution. If you only watch scope, or very rarely do 1.78, I can see it. But kinda the point of using a A lens in the first place was to use your full panel to produce the best resolution. If you downscale in order to get a 1.78 through a lens, you aren't. And what happens if you want to watch something like Casablanca that is nearer to 4:3. You are getting a strip of data and expanding it. Since I make a lens transport I'm obviously biased, however I got into that world because I wasn't willing to sacrifice those pixels. Particularly since I watch a LOT of HD TV and I want the full resolution. Plus, in 16:9 there is no scaling going on, 1:1 pixel mapping. I don't' scale unless I need to (2:35).
Yeah, list price is on up there. Street is better but it's not cheap. It WILL light up a big screen though.
http://www.digitalprojection.com/BrowseProjectors/SeriesList/ProjectorList/ProjectorDetail/tabid/87/ProjectorId/162/MarketTypeId/11/Default.aspx
Cheers,
Scott
Becasue you are throwing away your vertical resolution. If you only watch scope, or very rarely do 1.78, I can see it. But kinda the point of using a A lens in the first place was to use your full panel to produce the best resolution. If you downscale in order to get a 1.78 through a lens, you aren't. And what happens if you want to watch somethign like Casablanca that is nearer to 4:3. You are getting a strip of data and expanding it. Since I make alens transport I'm obviosuly biased, however I got into that world becasue I wasn't willing to sacrifice those pixels.
Yeah..I'm aware of the reduction in vertical resolution, but with HDTV (for want of a better word :D ) as most so called HD on TV is more like SD anyway,,with a few exceptions..so it doesn't bother me..
As for 4:3 movies, I never watch them..That AR dates them to era's that doesn't particularly interest me..even though they were made in my era!! :eek:lddude:
To see a movie like Avatar in scope (even though it was only made in widescreen) is quite breathtaking..even if you do occasionally lose a bit top and bottom!
It looks to be quite a powerful, solid unit..
One thing I did notice though is that it has quite a high fan noise at 35dB. You wouldn't want it over your head!
Thing is it's so bright I run it in eco mode. Bulb will last forever even after some aging be plenty bright. In eco mode it's not loud. A good bit Quieter than the JVC RS35 I had in here for a customer anyway. Plenty of extra umph if I want to turn it up in 2.35 mode.
81 - 88 of 88 Posts
